Luis' Build
lrodriguezrullan
Re: Luis' Build
Post by lrodriguezrullan »
Thanks. I will resolder the SIMM socket and try pushing different parts of the board.
Yes. I always get the same error.
Re: Luis' Build
Also check resistance from 0v and 5v to all DRDx pins on the simm. Make sure no low resistance values there.
Also check the buffer ic where DRD8 passes looks soldered OK.
lrodriguezrullan
Re: Luis' Build
I am taking another look at this while on vacation.
The diagnostic cartridge returns this over the serial port:
<0D><0A>I1 RAM/data line error 0000000000000000 0000000100000000 000008
I checked resistance from 0v (pin 1) and 5v (pin 10) to each of the DRD pins on the SIMM socket. There were no low resistance values.
I double-checked the solder on the SIMM and pushed different parts of the board while running the diagnostics. I also tested with a different SIMM. The results were the same.
Not sure where to go next.
Re: Luis' Build
Looking at this image viewtopic.php?p=90359#p90359
Have you checked either side of that track on the simm and check the entire track length for continuity.
Also have you checked for sold the blobs on the top side of the motherboard underneath the simm socket?
lrodriguezrullan
Re: Luis' Build
Yes. I was able to trace continuity all the way from the SIMM to the MMU, skipping the 74LS244.
Can you tell me more about what to look for on top of the motherboard underneath the SIMM socket?
Thanks.
Re: Luis' Build
lrodriguezrullan wrote: 13 Jun 2023 23:42 Can you tell me more about what to look for on top of the motherboard underneath the SIMM socket?
The pins which come from the bottom of the simm socket, there is a few mm of legs showing which are on top of the motherboard... If you applied to much solder it blobs across the pins and shorts them.
lrodriguezrullan
Re: Luis' Build
I do see some solder blobs. I will take a closer look. Thanks!
lrodriguezrullan
Re: Luis' Build
Can we use the multimeter to detect if these blobs are shorting the pins?
Re: Luis' Build
lrodriguezrullan wrote: 14 Jun 2023 00:13 Can we use the multimeter to detect if these blobs are shorting the pins?
Yes. You need to follow the image I posted earlier as some pins are connected together.
lrodriguezrullan
Re: Luis' Build
I apologize. I can’t figure this out. It is over my head.
Is there someone I can ship my board to, than can try to fix it? Of course I will pay him. Thanks.
Return to “H5 C1 USER BUILDS”
