Icky - Progress
Re: Icky - Progress
exxos wrote: 18 Sep 2018 20:00
Forgottenmyname wrote: 18 Sep 2018 19:57 Just quoting you on that.... for the record like.....
No problem :)
I've checked all around the CPU.. I mean really it should be booting up... Have to see if Icky has any luck...
Right I am caught up extra SIL in place but still no joy.
Need to measure a few things now
Re: Icky - Progress
Icky wrote: 18 Sep 2018 20:41 Right I am caught up extra SIL in place but still no joy.
damn :( Not sure what else to check at the moment.
Re: Icky - Progress
I think if your switching to 50hz then TOS must be running to a point, so not long after looks to be like MMU setup, then onto RAM setup.. So might be worth checking out the RAM side of things on the PCB, and even double check what I've wired in the diagram..
I am checking things out myself, not found any issues yet.
kodak80
Re: Icky - Progress
Post by kodak80 »
No problem :)
Can you add a photo of the SIL in place? I am trying to keep up with mods while I wait for a few components for my board.
Re: Icky - Progress
kodak80 wrote: 18 Sep 2018 22:23 Can you add a photo of the SIL in place? I am trying to keep up with mods while I wait for a few components for my board.
Sure, its not elegant as it was a quick fix.
I actually used the SIL to do the BGACK PULL UP FIX as well. You can see the common pin going to the 5V of the capacitor and am using insulating tape so as not to short anything.
kodak80
Re: Icky - Progress
Post by kodak80 »
Icky wrote: 18 Sep 2018 22:41
Thanks, looks fine to me.
Re: Icky - Progress
Are you still seeing 50hz set on boot ?
Re: Icky - Progress
exxos wrote: 18 Sep 2018 22:50
Yes on start it goes from 59.9Hz to 49.7Hz on my scope
Re: Icky - Progress
Icky wrote: 18 Sep 2018 22:54 Yes on start it goes from 59.9Hz to 49.7Hz on my scope
Just for hell of it, just try lifting up the ROM in the socket a tiny bit... I can only think ROM starts running then dies a few address lines up...
Do you get activity on all data & address lines ?
Re: Icky - Progress
exxos wrote: 18 Sep 2018 23:08
OK - I found some bad soldering on the RP6. I cleaned it up and now I am getting bombs but the screen is still all over the place. Let me attach a video
Return to “ALPHA USER BUILDS”
Users browsing this forum: ClaudeBot and 19 guests
