Looking through the booster section, although discontinued :
viewtopic.php?f=4&t=21
This booster is perfect for what i want (and maybe other people too), would have near maximum compatibility, extremely low profile (I have my CPU socket under bottom of keyboard) and doesn't require any other TOS upgrade board etc. for those that just want to tweak and not pimp :geek:
As my CPU is socketed anyway its a near plug-n-play scenario a small boost for a small 'cost' in time and effort.
@exxos no chance of a resurrection maybe? Have you allowed others to make this board i.e. is it on PCB way or the like or do you have some still hidden down the back of the sofa that we can still buy . . . :-D
ST V1 16MHz BOOSTER
Re: ST V1 16MHz BOOSTER
V1 got superseded by the V1.5. viewtopic.php?f=5&t=22 V1 doesn't speed up ROM, all the others do.
It's successor actually ends up being this viewtopic.php?f=104&t=3825 Should fit under the keyboard if you solder the CPU directly into the booster and solder the booster into the motherboard.
I think I ended up chucking away a lot of the V1,V1.5 boards in the end. I did offer them up for sale on the forum years ago but nobody was interested IIRC.
I mean sure, I could probably find the gerbers somewhere and upload them if you really wanted. But I don't really see the point in going backwards in booster design to that extent personally.
jwd
excellent, thank-you.
Another small project i can get my teeth into and actually finish, seems the big ones always end up on a shelf in pieces!
Users browsing this forum: Bing [Bot], ClaudeBot, petal [bot] and 10 guests
