- Board built without blitter and using Exxos Ram Board with a 4MB SIMM installed.
- Modifications installed so far https://www.exxosforum.co.uk/forum/viewtopic.php?f=19:
- Jumper Pads - SJ1 - 5 all linked (soldered)
- Reset Fix - R920 leg moved to be soldered to diode, tracks cut and patch wire in place
- Hsync Fix - Pin 8 leg removed from U51 socket and Pin 8 and 9 on underside of board soldered together
- Using the scope on the GLUE the board is producing 15.6kHz and 50Hz out. For the 50Hz it is initially 60Hz then immediately goes to 50Hz
- On every switch on or reset I get a full white screen that turns to black screen with white border. Sometimes it stays solid but more than often it starts scrolling horizontally.
Icky - Progress
Icky - Progress
Here is the current status of my board so we can track progress of where each of us are:
Re: Icky - Progress
I would first double check continuity on the ROM socket first of all.. socket problems are pretty common :(
Sounds like your getting some TOS init at least, it must be setting the palette to get a full white screen.. but never seen it go black after that..
Also please check BERR on the CPU...
Re: Icky - Progress
Checked continuity and socket is ok.exxos wrote: 18 Sep 2018 15:21 I would first double check continuity on the ROM socket first of all.. socket problems are pretty common :(
BERR on CPU goes high 5v at start and stays there
Re: Icky - Progress
What about BG, BGACK, BR ? All those should stay high all the time...
Re: Icky - Progress
BG and BGACK are high all the time but BR is low all the timeexxos wrote: 18 Sep 2018 17:33 What about BG, BGACK, BR ? All those should stay high all the time...
Re: Icky - Progress
hmmm, AFAIK nothing should be requesting the bus during startup (other than DMA stuff, blitter, ) Even so, CPU isn't granting the bus to anything either.. so that is odd...
Re: Icky - Progress
hmmm.. I can't see a pull up on BR anywhere... so checking to see whats happened there...
Re: Icky - Progress
OK.. "bodge wire 1" time...
Re: Icky - Progress
OK - Lets give it a go
Re: Icky - Progress
Looks like BGACK hasn't a pull up either :roll: out of room on the RP's, so bodge resistor time...
Users browsing this forum: ClaudeBot and 16 guests
