Theres 4 caps around the DMA already.. no need to add a 5th..Realloy wrote: Mon Sep 17, 2018 8:33 pm i can see all the chips have a decoupling capacitor,,, but what about BAD DMA ? is there one and where? or is it not necessary?
ALPHA MODIFICATIONS
Re: ALPHA MODIFICATIONS
For the sync fix I pulled both pins 8 and 9 out of the U51 socket and then jumpered the socket.
Do you have a photos of the change for us less technical builders? And did this resolve the sync problem?Forgottenmyname wrote: Tue Sep 18, 2018 10:45 am For the sync fix I pulled both pins 8 and 9 out of the U51 socket and then jumpered the socket.
Hopefully you can see it on here.
It didn't sort my sync problem but will work on that.
- Attachments
- 20180918_111006.jpg (3.78 MiB) Viewed 6493 times
You shouldn't pull pin 9 because you will have 2 floating gates in the chip then due to disconnected inputs.Forgottenmyname wrote: Tue Sep 18, 2018 10:45 am For the sync fix I pulled both pins 8 and 9 out of the U51 socket and then jumpered the socket.
Ok will put 9 back in, good point
BR PULL UP FIX
Bodge wire 1... Wire the thick yellow drawn wire as shown on the back of the pcb...
(Fixing missing pull up resistor on BR).
BGACK PULL UP FIX
Bodge resistor 1..... 2.2K between the 2 circled points on back of CPU socket...
(fixes missing pull up on BGACK)
I'm confused by this being connected to BR.exxos wrote: Tue Sep 18, 2018 6:23 pm Bodge resistor 1..... 2.2K between the 2 circled points on back of CPU socket...
Its a missing pull up resistor on BR & BGACK.
