Getting there !
Should exxos design a new CT60 PSU?
- HigashiJun
Re: Should exxos design a new CT60 PSU?
Looks really good !
How did we all live before A.I.
Built myself a really cool 3-D rendering engine where I can line up 3-D objects and everything is drag-and-drop them, because there are so many bad 3-D object files out there, I can simply grab a zip dump it on the browser and it will just update. So everything is really quick easy and simple
And in the case of fuse holder, I could not find any sort of fuse holder which was close to the ones I used.. So my new best friend made me one
PSU PCB now on order. Couldn't get the inductors, so had to order those from Mouser and will have to fit them myself.
Also just sent off for the 2 cables to be made. One is a Falcon PSU cable for the CT60. The other is a ATX cable to go from the PSU to the CT60 / CT60e.
Everything is a bit rushed, that's the problem. Couriers double the prices towards the end of the year. So have to get everything on order now , otherwise it be in the new year. So hopefully I've not screwed anything up.. But that be a first
