"SuperVidel" style graphics for the DFB1X2?
Re: "SuperVidel" style graphics for the DFB1X2?
alexh wrote:What does that mean? You modified Hatari to include the memory mapped HW you intend to build and then using existing/modified drivers demonstrated a working AES + VDI (nVDI?)?
Yes, pretty much. I added a model of the board to Hatari, so it has its own 8MB of screen memory and a small block of registers, and the Hatari display shows the board's screen when it is switched on. The addresses are placeholders for now, and it only proves the software side, not the timing of the real hardware.
There are no new drivers. A small setup program in the AUTO folder points TOS at the board's memory, sets the mode, and fixes up the screen size so the existing AES, VDI and Line-A all use the bigger screen. There is also a test program that draws into every corner of a full size window, does a blit to the far corner and reports what GEM thinks the screen is, plus a console scroll test and a direct screen write test.
I've run it on TOS 4.04 and EmuTOS 1.4 in 1, 4, 8 and 16 bit modes, up to 1920x1080 in 256 colours on EmuTOS. On TOS 4.04 the 16 bit modes work with the normal TOS VDI. The 1 to 8 plane modes need NVDI, because TOS 4's own VDI draws those with the Blitter, and the Blitter can only reach ST-RAM. With NVDI 5.03 loaded they all work. The screenshots are TOS 4.04 with NVDI at 1024x768 in 256 colours.
alexh wrote:Would you consider a digital RGBS input so you could combine native video with the new gfx card? (e.g. Scandoubler pass through) this would considerably improve the usability of the system.
In theory it would be possible, but it would mean getting at the Falcon's video before it turns into analogue and feeding that into the FPGA. There is no simple way of jacking into that without getting into the analogue side of the Falcon, which adds a lot more complication. The board only sits on the 030 bus, so for now the normal Falcon video output is left as it is, and you would just have two outputs
kgilmore
Post by kgilmore »
>>So, would anyone actually use it?
I would.
>>And what would you want from it, higher resolutions on a modern monitor, faster GEM, or something else?
Higher resolutions and faster GEM on a modern monitor would fit the bill nicely. 1280x1024 and 256 colours would be more than acceptable.
Atari Mega ST4, Atari Falcon030 14MB.
kgilmore wrote:Higher resolutions and faster GEM on a modern monitor would fit the bill nicely. 1280x1024 and 256 colours would be more than acceptable.
Thanks, that is useful to know. 1280x1024 in 256 colours already runs in the Hatari tests under EmuTOS, so the mode itself shouldn't be a problem.
The resolution isn't really the issue, it's the bandwidth. A full 1280x1024 screen in 256 colours is 1.25MB, and every bit of that has to be written by the CPU whenever the screen changes. You can already see this on a stock Falcon, where the true colour modes are fine for showing a picture but far too slow for anything that updates the screen much.
The difference with this board is that the CPU will have a full 32 bit path to the new Videl's memory, running at 50MHz instead of the Falcon's 16MHz bus, and the screen won't be sharing ST-RAM with everything else. So it should be capable of quite a lot, but the bandwidth will still set how quickly the screen can be updated, the same as it does on the Falcon now. It will just be a lot faster at it.
exxos wrote: Mon Nov 23, 2026 10:45 am
I know.
exxos wrote: Mon Nov 23, 2026 10:45 am There is no simple way of jacking into that without getting into the analogue side of the Falcon
U30. This is the Falcon STV8438CV Video DAC. It has 18-bit digital RGB that comes direct from Videl. In the new ReFalcon there is a connector here but I imagine for stock Falcons it might mean soldering or a clip-on interposer (depending on the DAC packaging)?
How do you envision it handling things like the mouse pointer? Software? Hardware?
alexh wrote: Mon Nov 23, 2026 11:40 am U30. This is the Falcon STV8438CV Video DAC. It has 18-bit digital RGB that comes direct from Videl. In the new ReFalcon there is a connector here but I imagine for stock Falcons it might mean soldering or a clip-on interposer (depending on the DAC packaging)?
I'm not quite sure what you mean about the mouse pointer? This sort of thing has already been done plenty of times in the past, even on the ST with things like the ET4000 graphics cards, so it's all possible.
I wasn't aware the ReFalcon had a connector for the video DAC, that's cool. But for a stock Falcon it would be too much of a problem asking people to solder all the wires onto the video DAC. Most people can't plug something in without breaking it!
So possible to fit a BGA chip on the DFB1X2 .. I'm asking my PCB houses if they can obtain the chip as it seems unobtanium other than China..
What I did was basically route the entire DFB1X on the top layer (around the PLD area) and the video board on the bottom layer. Then "merge" both of those routes together back into the DFB1X .
Next is a load of IO buffers...
exxos wrote: Mon Nov 23, 2026 12:44 pm
alexh wrote: Mon Nov 23, 2026 11:40 am How do you envision it handling things like the mouse pointer? Software? Hardware?
But did you do it? I thought you simulated it in Hatari? Did the mouse pointer work?
ET4000/W32 has hardware cursor and Blitter. (Dunno if the Nova fw uses it?)
