@agranlund did you need to use the IDE byte swapper?
I've never used MagiC, do you think it'll be worthwhile me trying to get it loaded? I have no idea what the benefits would be. It looks to be an alternative to Tos?
Yep, it's a TOS alternative.PhilC wrote: Fri Jun 27, 2025 8:09 pm I've never used MagiC, do you think it'll be worthwhile me trying to get it loaded? I have no idea what the benefits would be. It looks to be an alternative to Tos?
Or perhaps better to describe it as a MiNT alternative since it's pre-emptive multitasking.
But in all honesty, nope I don't think it would be worthwhile
MiNT is probably better and still in active development.
It's mostly a case of seeing if I could, and because my 68030 ST ran MagiC most of the time.
Not sure how much effort I will be putting into completing MagiC's Raven specific support but at the very least it needs to get support for input
It does require the byteswap adapter. Then I made a TOS partition with HDDriver installed in the bootsector.
That could be fixed but would take a lot of work that I don't think is worth it. You'd probably want to rip the IDE code from EmuTOS and transplant it into the MagiC kernel, or perhaps make standalone driver from said EmuTOS code.
Thanks, I did do some googling and wasn't sure about it. I'll keep my efforts focused on Emutos instead
Magic is fast. Probably beats TOS. On something like a 16 mhz 68k preferably with a graphics card it’s really impressive.
I totally agree! It’s really impressive stuff and I preferred it over Mint on the ST.Oldskool wrote: Fri Jun 27, 2025 9:53 pm Magic is fast. Probably beats TOS. On something like a 16 mhz 68k preferably with a graphics card it’s really impressive.
Another quick question - has the ROM programmer board been tried with 74LS family ICs? Or does it really need to be 74HC? The logic levels are a bit different but sometimes they can be swapped.
d:m:l
I used 74LS273 chips without issue using the PLCC romsdml wrote: Sat Jun 28, 2025 1:21 pm Another quick question - has the ROM programmer board been tried with 74LS family ICs? Or does it really need to be 74HC? The logic levels are a bit different but sometimes they can be swapped.
Thanks again! I'll take another pass through my logic array... I sorta rejected any tray that wasn't HC on the first round.
...well, I found one. Just one
Maybe I can multiplex it or something. Or move it between sockets very very fast
d:m:l
