Hi,
Time for another short update.
Board is progressing…
Did some tests with the Diag card and attached test harness
- IMG_0878.jpeg (596.59 KiB) Viewed 1323 times
Most of the tests worked out fine, except
- Joystick (most probably because of the Eiffel issue, still at original 1.10 firmware)
- printer port tests were failing - but read elsewhere that this often happens even if port is good. Need to look for a different test… do not own a parallel printer… and will not buy one…
- Floppy tests failed - maybe the Diag does not like the Gotek (because normal operation with the Gotek works just fine)
VGA card is also working fine, together with Idek‘s driver and NVDI 5.03 (as GDOS)
Have a ET4000 with 24Bit RAMDAC, so managed to get 1024x768 with 256 colors
But, man, is the system slow and RAM hungry with plain 8MHz 68k
- IMG_0888.jpeg (347.66 KiB) Viewed 1323 times
Burned EmuTOS 1.3 together with TOS 2.06. works great
Before I had TOS 1.04 (with IDE boot patch) and 2.06 running
So changing decoding and the bank with the two jumpers works just fine
- IMG_0887.jpeg (431.75 KiB) Viewed 1323 times
Next test will be, hooking up a real Floppy and testing HD mode - maybe I need to swap the WD with the Ajax, now that nothing seems to burn any chips
Mounted it inside the ATX frame (sliding into the case later) and connected most ports, CF reader and VGA card
- IMG_0886.jpeg (555.18 KiB) Viewed 1323 times
Cheers
Michael
