TF360 Status
Locked
Re: TF360 Status
the one that makes it to workbench... give the whole thing ten mins running then try it... i've no idea why but it seems to help.
alenppc
Re: TF360 Status
Post by alenppc »
terriblefire wrote: Sun Sep 08, 2019 5:49 pm
8 Bit Dreams wrote: Sun Sep 08, 2019 5:44 pm Guy's try traco power TSR 2-2433
Mouser number: 495-TSR2-2433
2A and no heat at all...
That looks good. Im just slightly concerned about the size of it. i.e. will it be too big to let a user install a TF360.
I think it should be OK, it's only 1cm tall, which is less than the IDE connector with the cable plugged in.
Re: TF360 Status
try gluing a heatsink to that regulator... that might get your rev 6 working.
alenppc
Re: TF360 Status
Post by alenppc »
I found this one, which is cheaper than the one Viktor suggested and it does the same thing:
https://www.digikey.ca/product-detail/e ... =303073267
Plus it's smaller in footprint. I am going to order it and try.
Re: TF360 Status
Pinout is different to the Tf360 pins at present.
alenppc
Re: TF360 Status
Post by alenppc »
terriblefire wrote: Mon Sep 09, 2019 2:33 pm Pinout is different to the Tf360 pins at present.
I know... but it seems that this is the most common pinout for these types of regulators. I'll rewire it externally.
Re: TF360 Status
Ok. I’ll look into re wiring the board too
Re: TF360 Status
Did a little bit of work on the board tonight. I have managed to get IDE working faster although i've seen a couple of lock ups too but im not sure if those are related to my change as the whole rig is a bit unsteady. Will monitor. I have sent AlenPPC my latest firmware.
Basically I realized you cannot run IDE at 80Mhz the way we've been doing it so added something i didnt want to add as a test..
Essentially when the CPU talks to FASTRAM it runs at 78Mhz (or its cache), When it talks to the Amiga it runs at 14Mhz. When it talks to the IDE interface it runs at 46Mhz. Which seems to work ok with the few cf cards i've tested.
I noticed one thing though. The CF card image supaduper sent me gets 3.5Mb/sec out of DH0: DH2: and DH3: but twice that from DH1... filesystem?
supaduper
Re: TF360 Status
Post by supaduper »
just checked my DH1 in Winuae and yes I must have left the max transfer setting from an another setup, its saying ffffff should be x1fe00 , which is odd as the filesystem is PFS3-aio lastest ver 19.2, and the max transfer really should not matter what setting is there as PFS3 will normally overide/handle that automatically, hmm strange,
go into HDtools in in Prefs/Tools and change the Max transfer to ffffff ( must hit enter after inputting otherwise will not accept it ) see if does the same for DH0
Re: TF360 Status
supaduper wrote: Mon Sep 09, 2019 9:49 pm go into HDtools in in Prefs/Tools and change the Max transfer to ffffff ( must hit enter after inputting otherwise will not accept it ) see if does the same for DH0
cant see hdtool under prefs anywhere .
Locked
Return to “TF360”
