TF536 on the ST
Other boosters or variants.
Re: TF536 on the ST
@terriblefire I thought it was my keyboards playing up but obviously not.
Yes EmuTOS works great with the card. The card I've built for @exxos has a constant reset issue with tos2.06 so we will have to work out what's different there.
frank.lukas
Re: TF536 on the ST
Post by frank.lukas »
How much Ram are on a TF536 and can it all use with TOS as Fastram ?
Re: TF536 on the ST
frank.lukas wrote: Wed Jul 01, 2020 8:47 am How much Ram are on a TF536 and can it all use with TOS as Fastram ?
64mb which is mapped as TT ram and can all be used in EmuTOS at least.
agranlund
Re: TF536 on the ST
Post by agranlund »
PhilC wrote: Wed Jul 01, 2020 8:49 am
It should all be available to TOS2.06 as well if running Maprom :)
Re: TF536 on the ST
This version has RAM mapped correctly, A bus error after fastram and all the A2000/A500 fixes incorporated.
All the mouse issues disappeared for me.
Try it out and report back please.
tf536r2_main_top_ATARI_FULL_PHASE_7.zip
(17.36 KiB) Downloaded 168 times
Re: TF536 on the ST
@terriblefire I've tried the new firmware. It seems to take about 60 seconds to get to the Emutos splash screen, it reports 64mb of TT ram but then doesn't detect any Hard disks.
Edit:
Just tried Tos2.06 and that boots pretty quickly which is good, no HD on that but thats the int2 issue.
Re: TF536 on the ST
PhilC wrote: Sun Aug 02, 2020 8:22 pm @terriblefire I've tried the new firmware. It seems to take about 60 seconds to get to the Emutos splash screen, it reports 64mb of TT ram but then doesn't detect any Hard disks.
OK i'll take a look. I didnt have a hard disk image handy
Re: TF536 on the ST
Another bit of info, just to rule out a dodgy board, I've tried it in another TF536 and it does see the HD partitions but they contain garbage files
Umberto1st
Re: TF536 on the ST
Post by Umberto1st »
Mouse problem is fixed.
1. Slow boot in emutos, 20 second white screen
2. No Ide in emutos. Tried with a card that was formatted with firmware dated 28_6_2020(which worked perfect) and the new firmware corrupted the compact flash card
3. No Ide auto boot in Tos 2.06 even with INT tethered. but the drives are readable and writable
oh ya no cards over 4 gig work and the ASCI port has never worked correctly
3)1040 stf/m, 2)Mega 4 ST, 1)STE, 1)Mega STE, 1)STacy, 2)Falcon 030
Re: TF536 on the ST
bare with me while i try and get both atari and working from one set of code..
I noticed i still had the Amgia boot rom mapped at 0xf00000 which might explain corruptions. try this...
tf536r2_main_top_ATARI_FULL_PHASE_7_danger.zip
(15.16 KiB) Downloaded 205 times
Return to “EVERYTHING ELSE”
