Badwolf wrote: Tue Sep 10, 2024 9:44 am
sdisla wrote: Mon Sep 09, 2024 3:27 pm
I replaced only four U63 U62 U67 U68, still waiting for U44 the one near the DSP side of the board.
! will keep looking, keep you posted, thank you for your support.
No worries. Keep looking. Check pins around the affected GAL for intermediate voltages or drift, etc. Check removing the GAL still resolves the problem.
Try to keep a written record. It will help as you'll have hundreds of things to check.
Good luck & keep going. You're getting closer, I'm sure.
@Badwolf
I did the measurements with the new ICs and for my surprise these GAL chips behave as blank ICs.
In order to sort this out I check with the scope the following combinations getting the same readings:
- AS A1 with new U62 U63 U67 U68 installed.
- AS A1 with new U63 U67 U68 installed no U62
Our current finding with the originals GALs
- AS A1 with no CHIP installed.
I reinserted the originals U63 U67 U68 no U62 and check for AS A1 and I get the correct reading 0101.
Let me see how I can get them back to the vendor to check if they are blank.
In the meanwhile, I will get the Lattice ICs as per
@frank.lukas suggested and program them myself.
We still have the chance that it could be a bad U62 or perhaps U44.
Keep you posted.
- AS A1 WITH ORIG GAL CHIP U63 U67 U68.jpg (76.01 KiB) Viewed 821 times
- NEW GAL CHIP.JPG (232.71 KiB) Viewed 821 times
