TOS RAM test routine ?
Re: TOS RAM test routine ?
stephen_usher wrote: Wed Dec 07, 2022 10:57 pm Thanks... About 2.5 seconds
It's very odd. I don't see anything else in the ram tests which are 306 related.
I will add instruction cache next but Hatari might not do anything. It may help on real hardware, but that's not running whatever 306 is doing. Even so its like 10x quicker by your accounts on 306 than 206. Other thank block size I don't know what else it could be doing.
@stephen_usher With vanilla 306 I cannot even see either ram test it just goes directly to desktop as well :roll:
@stephen_usher Are you able to test this one on TTram test speed? Or basically just compare both RAM speeds compared to TOS306..
000.zip
(127.23 KiB) Downloaded 48 times
Thought I found a good place to switch to medium resolution on boot up.. Only that obviously did not go to plan somehow :lol: :roll:
exxos wrote: Thu Dec 08, 2022 3:35 pm @stephen_usher Are you able to test this one on TTram test speed? Or basically just compare both RAM speeds compared to TOS306..
or maybe @Badwolf https://www.exxosforum.co.uk/forum/view ... =80#p95225 (it should enable instruction caches now) *HOPE* that will fix the slow issue.. if not.. I give up :)
exxos wrote: Thu Dec 08, 2022 3:54 pm Thought I found a good place to switch to medium resolution on boot up.. Only that obviously did not go to plan somehow :lol: :roll:
Careful with that. Lots of floppy-booted games don't bother to change res. PITA with EmuTOS on Falcon.
exxos wrote: Thu Dec 08, 2022 9:16 pm
I'll give it a go to check if the cache is enabled, but I can't measure the speed differential (for reasons previously stated :) )
Badwolf wrote: Fri Dec 09, 2022 11:29 am
Ah yes good point.
Badwolf wrote: Fri Dec 09, 2022 11:30 am I'll give it a go to check if the cache is enabled, but I can't measure the speed differential (for reasons previously stated :) )
Thanks. I'm slightly confused if it is making a difference or not in Hatari. I cannot really do anything else but enable the cache anyway. So it is pretty much end of the road now either way.
exxos wrote: Fri Dec 09, 2022 11:43 am
Runs the same speed as before, but yes, CACR is now set to 0x3111 (both caches enabled). This seems odd to me (why data cache when testing memory?) but it's like it under TOS3.06 and I suppose if you're scanning everythign once the cache will miss all the time anyway.
So this ought to be faster on the real hardware. :thumbup:
