Turning on STacy only 2 times out of 10 does it start.
Roberto
Re: Turning on STacy only 2 times out of 10 does it start.
Post by Roberto »
I fixed it... I hope the problems end here.
A user on the Atari Forum passed me the .JED file to write to a normal GAL16V8D and I substituted it for the PAL, which I discovered was all 1, probably canceled by the CPU short circuit last summer.
Ultimately it was the Real Time Clock circuit that was causing these power up problems.
Thank you all and to you @derkom who gifted me the LCD screen. I really don't know how to thank you.
Now I'm slowly reassembling, piece by piece my beloved STacy... I think it will be the Atari that I will use the most among those I have :-)
This is the .JED file for the RTC, if anyone could help. Just strip that trailing .txt before writing it.
mega_uhr.jed.txt
(2.4 KiB) Downloaded 48 times
Good stuff, glad you finally got there in the end.
:girldance:
Darklord
Post by Darklord »
Yes, congratulations! (and another STacy rejoins the fray!) :dualthumbup:
:yay: :dualthumbup: :girldance:
Roberto
Post by Roberto »
Darklord wrote: Fri Mar 10, 2023 4:30 pm Yes, congratulations! (and another STacy rejoins the fray!) :dualthumbup:
I will now follow up with your upgrades starting with replacing the original HD. I have both an internal BlueSCSI (but it seems not the best for the Atari as I can't set the LUNs to show them as SCSI-IDs) and a SCSI2SD; I still have to experiment with this one. I wouldn't want to spend more suns, for example taking an internal ULTRASATAN, because I know this would be fine. So I have to "make do" with BlueSCSI or SCSI2SD.
