DMA port "update" ideas..
kodak80
Re: DMA port "update" ideas..
Post by kodak80 »
exxos wrote: 28 Oct 2018 12:29
kodak80 wrote: 28 Oct 2018 12:25 This may be another source but not PCB mount:
Thanks, it could be possible to bodge them in with a adapter pcb or something I guess...
Yep, that was my thinking. Would need some right-angle pins and maybe a 3D printed plastic block to have the pins go through with a couple of square nuts on either side to mount the hex nuts.
Maybe the right-angle pins would be enough on their own. The plastic may only be needed to mount the nuts on each end.
I saw these ...
https://www.amedia-computer.com/en/hard ... apter.html
So as thats not a proper connector, if a 25way DB25 for example was done, it could still plug into it... and it would allow Ultrasatan to be used on a 25way connector... would have to be careful about if it was inserted incorrectly though...
Doesn't solve old DMA drives, but I guess there is less need for adapter cables for old drives to be used on the new MB... But cables could still be made.
exxos wrote: 28 Oct 2018 13:42 I saw these ...
If we went to a 25 way we would be back again, as you righty say, adaptor cables. Its a bit chicken and egg this trying to preserve 100% compatibility :(
IngoQ
Post by IngoQ »
Lotharek has DB19 plugs in his store, maybe worth a shot asking him?
https://lotharek.pl/productdetail.php?id=74
Ingo :geek:
IngoQ wrote: 29 Oct 2018 12:19 Lotharek has DB19 plugs in his store, maybe worth a shot asking him?
We can get the plugs no problem.. we need pcb mount sockets...
IngoQ
Post by IngoQ »
Yes I know. As far as I know, he had these ACSI plugs made, like he had the Atari SIO plugs made. Maybe it is possible to offload the making of pcb mount sockets to him?
Ingo :geek:
IngoQ wrote: 29 Oct 2018 12:57 Yes I know. As far as I know, he had these ACSI plugs made, like he had the Atari SIO plugs made. Maybe it is possible to offload the making of pcb mount sockets to him?
Have a look at this post...
https://www.exxosforum.co.uk/forum/viewt ... =70#p12443
IngoQ
Post by IngoQ »
Oh I see, probably Lotharek was part of that group buy...
But he had the SIO plugs made: http://atariage.com/forums/topic/206363 ... ari-plugs/
Admittedly these are much simpler than the pcb mount sockets, so just ignore my rambling ;)
Ingo :geek:
IngoQ wrote: 29 Oct 2018 13:56 But he had the SIO plugs made: http://atariage.com/forums/topic/206363 ... ari-plugs/
I had not seen that... Looks like the costs are too high though :(
I guess if it was simple, he would have already started producing them as a proper connector for ultra Satan..
I can see it just ending up being a normal 25 way connector at this rate.. At least a good thing there is we can route power to the connector as well..
IngoQ
Post by IngoQ »
And if someone really needs it, adaptors could be made, like in here: https://www.exxosforum.co.uk/forum/viewt ... =80#p12455
Maybe not the prettiest thing on earth, but functional. For more common expansions like the UltraSatan, a direct attachable cable from DB25 to IDC20 could be a simple option. The included power suppy would be nice as well with the added benefit of not having two separate power supplies and therefore having two ground potentials.
Ingo :geek:
Users browsing this forum: ClaudeBot and 2 guests
