ST536 STE EDITION
Re: ST536 STE EDITION
Won't that be slower than the original test?
Yes, but more thorough.
The original test won't pick up addressing errors
I'm looking to speed it up by like 50% without sacrificing to much testing wise. There's YAARTT for in-depth testing.
If you know at boot time where and how much ram should exist, the march test is the best & simplest way to verify the RAM is good. The mapping thing I suggested above is useful when the RAM config may depend on other factors like the user, jumpers, board revision, IC / SIMM sizes etc. etc. as it will find the RAM for you.
For this board though, maybe that config is always fixed (?) so going straight to a march test without mapping might be good enough.
d:m:l
Off topic: I wish YAART would add a March test. It won't detect addressing errors with the tests it's doing, well, only a few with "own address".
The OS should only be used on the STE536/ST536 and its always going to have 64MB RAM. I just find the power up TTram check very useful, it just takes way to long.
But the original test doesn't test own address which checks bad address lines, so I think that is a must , rather than writing more "fixed" values. Then the walking 1s would test every bit. I think that's better and quicker than the original tests and should be a bit faster as well.
Technically bht walking 1s would kinda detect bad address lines as well as the bits should be wrong. But I think address test is a good one to have ?
Yeah. Maybe I will get AI to write a new TTram tester one daystephen_usher wrote: Sat Jun 14, 2025 10:05 am Off topic: I wish YAART would add a March test. It won't detect addressing errors with the tests it's doing, well, only a few with "own address".
Right. So for a 'quick' power-on ram test, a page-based own-address test with a very limited bit-level test per page seems like a good option vs a full march test on everything.exxos wrote: Sat Jun 14, 2025 10:10 am The OS should only be used on the STE536/ST536 and its always going to have 64MB RAM. I just find the power up TTram check very useful, it just takes way to long.
Having an option to properly test the whole lot would be nice though, maybe with some held keys or whatever. But as stephen_usher wrote, diagnostic tests like YAART should really be using march for certainty.
d:m:l
"Own address" will only catch address errors which (a) are out of cadence with the address rotation, (b) affect all bits equally.exxos wrote: Sat Jun 14, 2025 10:10 am Technically bht walking 1s would kinda detect bad address lines as well as the bits should be wrong. But I think address test is a good one to have ?
e.g. address error only affects the lower 8 bits and repeats memory every 1K. Own address won't spot this at all.
Because a March test uses in-RAM data and progressively modifies it by XORing any faulty addressing will flip the bits multiple times and amplify the resulting change. This is why it's so good at spotting addressing errors.
Yeah having a extended test could be a good feature on a keypress or something. Not sure what key as TOS uses a few already for various things. Though possible something like the control key before the RAM test wouldn't effect anything at that point anyway I guess..dml wrote: Sat Jun 14, 2025 10:20 am Having an option to properly test the whole lot would be nice though, maybe with some held keys or whatever. But as stephen_usher wrote, diagnostic tests like YAART should really be using march for certainty.
I suppose TOS could have its own built in version of something similar like YAARTTT. Having a bit more diagnosis built in would be useful.
