agranlund
Post by agranlund »
Oldskool wrote: Mon Dec 09, 2024 4:51 pm Would it be possible to make some binaries available of a game port(s) you did for the Raven?
Here are some but they should all be considered work in progress :)
OpenTyrian: https://github.com/agranlund/opentyrian ... tag/latest
- No sound, No music (hardware OPL is almost done but disabled in the release.
Doom: https://github.com/agranlund/pmdoom/releases/tag/latest
- No sound, No music (hardware MIDI & OPL is wip but disabled in the release)
Quake: https://github.com/agranlund/quake/releases/tag/latest
- No sound, No music, No input
This is more of a proof on concept to add support for non-Falcon hardware.
Since there is no input yet you can only watch the self-running demo but not actually play or quit the game.
They all need the original data files from the PC versions.
OpenTyrian and Doom is using SDL so you'll need to configure your system variables accordingly.
I recommend this for programs built with recent enough SDL which has xbios input support:
SDL_VIDEODRIVER=xbios
SDL_ATARI_EVENTSDRIVER=xbios
If you run SDL games under plain TOS you'll need some third party application to actually set these variables.
The latest Raven package has been updated to include "setenv" by Vinz/MPS, together with a pre-configured setenv.txt, but you could use any other similar program too.
https://github.com/agranlund/raven/rele ... A1.latest
mikro
Post by mikro »
That OPL and MIDI stuff is indeed begging to be included on machine like yours! :-)
agranlund wrote: Fri Dec 27, 2024 12:59 pm OpenTyrian and Doom is using SDL so you'll need to configure your system variables accordingly.
Just to clarify: those variables are needed/recommended only for the executables already built & provided by @agranlund. Latest SDL will use those automatically on TOS >= 2.x machines.
agranlund
Post by agranlund »
mikro wrote: Fri Dec 27, 2024 3:29 pm Just to clarify: those variables are needed/recommended only for the executables already built & provided by @agranlund. Latest SDL will use those automatically on TOS >= 2.x machines.
Ah, good call! Thanks @mikro . I'll fetch and rebuild against latest SDL, very nice to not need SDL environment variables.
Especially since TOS doesn't really support them in a good way :)
Oldskool
Post by Oldskool »
Thanks for the ports… :D
As for the music I will just sing them.
Ta ta ta tada ta da ta taaaaa ta ta ta tada ta da ta taaaaa…
agranlund
Post by agranlund »
Oldskool wrote: Fri Dec 27, 2024 6:39 pm Thanks for the ports… :D
Haha brilliant! :lol:
I've rebuilt Tyrian + Doom against latest SDL and uploaded new release executables so you can disregard all the previous stuff about SDL environment variables.
(This SDL appears to have some issue restoring the screen going back to TOS but it looks fine in Mint. Something to take a look at later since it didn't happen in the old one)
Tyrian is using FPU a little bit but as far as I can tell it runs nice and fast even when built with soft-float, so the latest release exe is built like that and should then hopefully work on 68LC060 too.
luciodra
Post by luciodra »
I tested them both in full screen, and they are smooth and playable. Great work, apart from the audio.
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
Oldskool
Post by Oldskool »
luciodra wrote: Fri Dec 27, 2024 8:38 pm I tested them both in full screen, and they are smooth and playable. Great work, apart from the audio.
Just sing the tunes with me you can do it…….
luciodra
Post by luciodra »
I know the Doom soundtrack by heart... I feel like I'm listening to it in my head... :lol:
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
agranlund
Post by agranlund »
luciodra wrote: Fri Dec 27, 2024 9:16 pm I know the Doom soundtrack by heart... I feel like I'm listening to it in my head... :lol:
But just in case you forgot, I'll help jog the memory :)
Oldskool
Post by Oldskool »
All I can say is :
