LarryL - another Raven060 Adventure
agranlund
Re: LarryL - another Raven060 Adventure
Post by agranlund »
LarryL wrote: Tue Dec 23, 2025 5:30 am I am also working with MacOS (newest version, apple silicon M2), so I will give it a try during Christmas…
Let me know if there are any bits that are wrong or simply missing in terms of setting up the environment for building the things.
Would be pretty good if myself, or someone else, did a from-nothing test and documented required steps in a small readme :)
In theory, it should be enough to install the two different atari gcc cross compilers, make the PureC cross compiler environment, and after that, make should just work for the different softwares.
Perhaps something also wants some additional library from Thorstens site. Libgem or something like that.
Hard to tell when you already have all that kinds of stuff installed from before :)
I'm running the older MacOS Monterey on an even older x86 MacPro 2010.
I've been wanting to get myself an ARM based one for years, but thanks to the PCIe slots that old thing has all the modern stuff as well as being quite snappy with dual Xeon cpus. So it just keep on living for far longer than it has any rights to :lol:
LarryL
Post by LarryL »
agranlund wrote: Tue Dec 23, 2025 7:56 am
LarryL wrote: Mon Dec 22, 2025 9:56 pm But: this broke Nova... Only get the message "STA_VDI not found" during boot - for any selected driver, except DEFAULT.
DEFAULT brings me to a b/w desktop - but this let me test Extendos
Edit: Going back to the original ROM brings back the working Nova setup
Where you already on release package 20251214 or later, or something earlier?
Some Nova driver compatibility related stuff was moved from rom and into rvnova.prg in 20251214 so I'm wondering if maybe you are on a version of rvnova.prg which is older than that?
(the rom I built should be identical to the one in 20251215 but with the addition of CONF_WITH_SCSI_DRIVER)
I thought I was already on the latest release - but I will double check this evening
Thanks for all your effort
agranlund
Post by agranlund »
LarryL wrote: Tue Dec 23, 2025 8:19 am I thought I was already on the latest release - but I will double check this evening
No worries! It looks like maybe there is something not behaving as it should after all, perhaps after those mach64 related refactorings.
It appears that I am locking up when starting MagiC with Nova enabled. I suspect perhaps because of the latest rom+rvnova changes but I'd have to spend a bit of time to verify if that's the case.
Edit: no, that looks like it was related to my setup of MagiC+Nova+Nvdi5
agranlund
Post by agranlund »
I saw that there was a couple of SCSIDRV related fixes in EmuTOS since the last version I integrated from.
So here's one with EmuTOS updated to latest, and with CONF_WITH_SCSI_DRIVER set to 1 for the Raven target.
rom_tos.bin.zip
(327.43 KiB) Downloaded 47 times
I'll test this a little bit here first before putting that into Ravens main repo.
LarryL
Post by LarryL »
Great, thanks.
Unfortunately - due to trying keeping a happy wife - I will not be able to do any test today :roll:
But tomorrow I will do some detailed checks with my CD ROM setup
Cheers
Michael
LarryL
Post by LarryL »
agranlund wrote: Tue Dec 23, 2025 6:00 pm I saw that there was a couple of SCSIDRV related fixes in EmuTOS since the last version I integrated from.
rom_tos.bin.zip
Managed to do some tests last night
Works flawlessly in my set-up :D
I think I still had a SW package from an older release running, so I updated to the newest and updated the ROM
Now Nova works again - and I can access a CD ROM via Extendos, as well as using HDDRUTIL for partitioning without prior loading of HDDRIVER
I used the newest 12.75 version, which worked well without showing the mirrored IDE devices
LarryL
Post by LarryL »
Hi,
although I copied the lates release to the CF (which solved the issues I had before), now I have a problem with my new Cirrus VGA card
It is a GD5424 card which seems to work
But only in b/w 640x480x1
I could not select any resolutions inside the BIOS and remembered, that I need to copy some BIB files
So I copied BIB files from the Nova/DEFAULT/AUTO folder into the Nova/CIRRUS/AUTO folder (this folder was empty)
New I can select resolutions, but result is the same - only 640x480x1
And I realized, that during boot Nova complains that the "version is too old"
@agranlund
What exactly needs to be in the Nova/CIRRUS/AUTO folder to get color resolutions with a Cirrus card?
sorry, if this might have been answered elsewhere
cheers
Michael
agranlund
Post by agranlund »
LarryL wrote: Wed Dec 24, 2025 4:55 am Managed to do some tests last night
That's awesome! Teamwork :)
Oh, did the Cirrus folder sneak in there? Ignore that one.
The 'DEFAULT' driver supports Cirrus, WDC, and generic VGA.
It's a terrible name.. so in a separate branch I was toying with splitting the stuff up into separate and sensibly named drivers -- apparently the empty folder carried over.
If using the default driver is still not working, try removing emulator.bib, sta_vdi.bib and xmenu.inf from the c:\auto folder
The correct ones will be automatically copied over again if necessary, depending on which driver you have selected.
LarryL
Post by LarryL »
agranlund wrote: Wed Dec 24, 2025 12:37 pm
Ok, that seems to work - at least I have color :D
But I expected the card to be a bit faster…
It is a GD5422 (not 5424 as I have thought)
Only in b/w it is much faster, esp. the blitting, compared to the AX I had before
Once color comes in, performance goes down close to AX level
Interestingly, the Nova boot messages reports ET4000/T8 as loaded driver - and booting takes much longer now (sitting at a white screen for about 3-4 seconds before the boot messages start)
BTW: Merry Christmas to all of you out there :mrgreen:
agranlund
Post by agranlund »
Ah, the GD5422 does not have a hardware blitter so it’ll likely perform similar to an ET4000AX.
GD5426 was their first model that came with 2D acceleration.
Glad to hear the driver works with the ’22 though!
I have only tested here with 26, 28, 29 and 34.
I’m using the VDI part from the ET4000/T8 package so it’ll say that when it loads. It’s somewhere in a todo to patch that message when I load and run sta_vdi.prg because it bothers me too :)
Merry Christmas!
