I don't doubt it!!mrbombermillzy wrote: Mon Mar 21, 2022 1:40 pmBeware! You can't unhear that music!rubber_jonnie wrote: Mon Mar 21, 2022 12:58 pm I will burn a ROM with Radar Rat Race on it and see if the music is as maddening as you suggest!!![]()
Whoops, I did it again! VIC-20 on the way...
Re: Whoops, I did it again! VIC-20 on the way...
Nice, so over lunch I tested the SD2IEC on the VIC-20 and it works fine and dandy
Ok, so this arrived today, just £20 from Retro Lemon:
Which allows for up to 35KB RAM, as seen here:
And I can also add up to 4 ROMs in banks via an EPROM in the empty socket, so I'll get some downloaded to play with
Now I have the SD2IEC working too, I have a pretty good overall VIC-20 setup
It had to be done!!
Ok, so I actually played it.
It's got a frame rate you can easily count, sound and music are, well, from the 80s though recognisable, BUT holy hell, it is 100% recognisable as Doom from just the 1st level.
Whoever built this did an astonishing job, it's quite staggering. Doom on a 35K VIC-20!!
My goodness! That is definitely a massive achievement.
- mrbombermillzy
Well, I've just had a look at a YT vid of it and it's pretty darn good for a VIC20!
That must have been harder to code than playing the game on nightmare.
Pretty amazing work, astonishing even.stephen_usher wrote: Wed Mar 23, 2022 7:03 pm My goodness! That is definitely a massive achievement.
