The Cosmic Puppet's Universe.
Re: The Cosmic Puppet's Universe.
Oh, I see. They've been moved to more conventional positions, following more standard HCI guidelines.
- Cosmic Puppet
Oh, okay.stephen_usher wrote: Thu Oct 28, 2021 3:57 pm Oh, I see. They've been moved to more conventional positions, following more standard HCI guidelines.
Thanks to Google, I know what that means.
@Cosmic Puppet See how much you can learn while using these obsolete systems!
If it was Windoze you'd find most things changing every few weeks & almost nothing would work like it used to....
- Cosmic Puppet
Was thinking that @JezC With EmuTOS there are people I can speak to if my programs behave differently.JezC wrote: Thu Oct 28, 2021 5:56 pm @Cosmic Puppet See how much you can learn while using these obsolete systems!
If it was Windoze you'd find most things changing every few weeks & almost nothing would work like it used to....![]()
ugh, Let's hope they don't start following Microsoft's layout of make everything in a plain white box methodology.. And web designers methodology of making things as hidden as possible and making as much work as possible for the user. It is normally the end when things start getting moved about unnecessarilyCosmic Puppet wrote: Thu Oct 28, 2021 4:29 pmOh, okay.stephen_usher wrote: Thu Oct 28, 2021 3:57 pm Oh, I see. They've been moved to more conventional positions, following more standard HCI guidelines.![]()
Thanks to Google, I know what that means.![]()
- Cosmic Puppet
exxos wrote: Thu Oct 28, 2021 6:06 pmugh, Let's hope they don't start following Microsoft's layout of make everything in a plain white box methodology.. And web designers methodology of making things as hidden as possible and making as much work as possible for the user. It is normally the end when things start getting moved about unnecessarilyThen the icons get fiddled with and they all turned into washed out grey colours with no contrast... I need to go look at some gem windows now and calm down...
I turned off the window shadows on my PC as I thought I didn't need it and it's just unnecessary processing. Then this morning I kept selecting the wrong window when two were open. When I checked what was happening, it was because I couldn't see the edge of the overlapped window, as it was white on white. Shadow is now back on.
- Cosmic Puppet
Bummer. Was working on stuff and got a ping from my head, so I loaded up Notator from disk and sure enough the update is changing more than Notator's file box.Cosmic Puppet wrote: Thu Oct 28, 2021 3:24 pmThe OK and CANCEL buttons have moved making the box bigger.stephen_usher wrote: Thu Oct 28, 2021 3:17 pm I can't see any difference. What am I supposed to be looking at?
Not life breaking, I just noticed when I was confirming that the lag on Notator without NVDI had gone on version 1.0.prg onwards.![]()
The lines that separate the options look like this:
But were originally this:
It feels a bit anti-nostalgic.
This is the build with 3D Objects turned off on the latest snapshot.
Version 1.0 is perfect.
I don't know why this stuff gets changed. I am with you on this one as well, I prefer to have more broken up lines rather than solid type lines. Have you looked if any of this has been recorded in the change logs anywhere ?
- Cosmic Puppet
I'm not wanting to cause trouble.exxos wrote: Fri Oct 29, 2021 7:59 pmI don't know why this stuff gets changed. I am with you on this one as well, I prefer to have more broken up lines rather than solid type lines. Have you looked if any of this has been recorded in the change logs anywhere ?
I just noticed it because my mind was distracted and that usually means something has changed.
I don't understand any of the programming stuff. Way out of my intelligence lol
Version 1.0 seems to work perfectly with everything on the new SD card I'm building. Just think it would be a shame if the software left me behind.
