Here is a photo of the capacitor in question.exxos wrote: 29 Dec 2019 00:03 Can you post a image of this ? I did moved a lot of caps away from the PSU legs already, I was limited on space after all the track moving in most places.
kodak80 H4 build (x2)
kodak80
Re: kodak80 H4 build (x2)
derkom
Do you have an especially large foot on your PSU bracket? Mine isn't very close to that capacitor once installed. I think perhaps you're just hitting the cap when installing the PSU, and should approach from a more vertical angle.
kodak80
I have my board in an ST case base and when fitting a PSU you have to angle it so that the PSU switch goes through the case hole so fitting it straight down is not an option with the board in a case.
derkom
I'm doing that, too, but I seem to be missing the cap. :)kodak80 wrote: 30 Dec 2019 09:07 I have my board in an ST case base and when fitting a PSU you have to angle it so that the PSU switch goes through the case hole so fitting it straight down is not an option with the board in a case.
I've moved it...
kodak80
Board number 2 now booting into DiagROM.
Not booting into TOS though. Need to check soldering and IC pins are not oxidised.
Looking good , can't be much wrong if your booting diagrom :)
kodak80
Just a couple of thoughts.
Once these new boards are ensconced in cases, it would be nice to have a badge on the outside to show what is inside?
Also, as these were a limited run, should they be allocated serial numbers for future posterity? I have tagged my two as AU1 and AU2 at the moment.
PaulJ
Sounds like your on the way. :) How are the other three boards doing?
kodak80
The other 3 boards have not yet been started. I may end up building 1 of the others as well. The other 2 may b a while before they are started as the owner is away from today for a few weeks.
2nd board is now booting to TOS after cleaning IC pins so must have been oxidisation stopping TOS booting.
Only seeing 2mb RAM at the moment as fix to the SIMM pins not yet done.
Users browsing this forum: ClaudeBot and 2 guests
