exxos's DFB1 trials
Re: exxos's DFB1 trials
I'm not aware of any potential conflicts. There isn't really much going on other than moving to a faster CPU and adding TT ram.
Though NetUSBee is renowned for having all sorts of weird problems by itself. There are all sorts of threads on the forum here of people doing patches on it. So may be worth looking into that...
will do thanks - now hitting problems getting NVDI to load for some reason but will keep on fiddling, I've no doubt done something wrong!
I don't have a NetUSB, but I have its ancestor (the Hydra) and *it's* ancestor (EtherneC). Obviously those don't have USB but they too can be a be flakey even on my 16MHz Falcon. The 50MHz one perhaps comes back to the card a bit too quickly sometimes and things stall a bit?
I think I've read some people had have trouble with NetUSB on the TT and my guess is it's the speed of the CPU too.
I'm not sure if the current production firmware lets you clamp the DFB1X at 16MHz with the OPTION jumper, but if it does, you could rule it out with that.
Thanks for the tips, I've unplugged for the time being to just focus on getting one thing working at a time!
Fun and games with NVDI at moment, never had this before!
NVDI sorted - I must have missed a file when copying over to the Falcon
Couple of obvervations:
Is it FAST
Holding down ctrl or alt at boot doesn't appear to have any effect
It takes a lot longer to change screen resolution that is used - probably an additional ten seconds - far from a huge problem just wondered if anybody else had come across this - I'm using the blowup s/w with the 3 in 1 vga adapter
Cheers,
Simon
Is it FAST
Cheers,
Simon
I've never seen any of those symptoms, no.smoore100 wrote: Mon May 20, 2024 4:37 pm Holding down ctrl or alt at boot doesn't appear to have any effect
It takes a lot longer to change screen resolution [than it used to]
Thanks for the help and tips, I’ll start a new thread on the NetUSBee stuff, found a potential solution which I’m hoping to try tonight.
Cheers,
Simon
Cheers,
Simon
I never got the USB portion to work on the Falcon with both the USBEee and the NETUSBee. HDDriver recognized the USB hub but not the USB memory stick.
The NET part works great though with the latest uiptool. I copy files on the Fakcon that way. My NETUSBee doesn't work on the TT, no NET and no USB.
smoore100 wrote: Mon May 20, 2024 2:55 pm Quick question, has anybody had any conflicts between the DFB1 and the NetUSB device?
I've tried a couple of USB sticks but they don't get recognised at boot up, although I can see the drivers are loaded.
When booted I can launch the USB utility and see the NetUSBee Root Hub, but again not the device itself.
Same with HDDriver, so I can't partition a stick.
Looks like it's back to using floppies again for the moment!
Feeling old yet?
Atari 1040STf, 1040STe, Mega ST4 (ST536), Mega STe, TT030, Falcon (DFB1x)...
...and a whole bunch of other retro computers
The NetUSBee-lite (network only) doesn't work on my TT either and never has. Nor have any cards which use "write using read".
Yep that's all I need - file transfers, I don't think there are any drivers that are needed for this either?HomeLate wrote: Tue May 21, 2024 8:54 pm I never got the USB portion to work on the Falcon with both the USBEee and the NETUSBee. HDDriver recognized the USB hub but not the USB memory stick.
Then I'll have to dig out an ethernet cable, haven't used one for years!
Cheers,
Simon
