HigashiJun wrote: Tue Oct 06, 2026 6:00 am I have the same setup and as you can see, the lower shield is also fitted:
Thanks for confirming. I don't remember removing it when I fitted mine.
HigashiJun wrote: Tue Oct 06, 2026 6:00 am But since this thread has put me off, I will now avoid using my Falcon.
If you're nervous, talk to Pavel, invite him to join Exxos Forum and politely be involved in the investigation. If he is a good guy, who likes his products and his customers he will have an open mind (if be a little defensive) and positively engage.
I don't know how long you've had yours but I've had mine for over a year and I've had the Falcon on once or twice a week. At least 100 power cycles. On 220/240v mains. That is not conclusive, there are some very good arguments being suggested as to how this happened. The fact it happened twice to the same user seems rather strange to me? No?
I also have to say, I don't remember ever connecting those two wires to the CT60e (might have done). I've only ever used it in 060 mode.
HigashiJun
Post by HigashiJun »
Badwolf wrote: Tue Oct 06, 2026 9:56 am
HigashiJun wrote: Tue Oct 06, 2026 6:00 am I will now avoid using my Falcon.
Bit extreme! :lol:
Until exxos sells his own CTPSU...
HigashiJun wrote: Tue Oct 06, 2026 10:31 am Until exxos sells his own CTPSU...
8-)
I'd suggest removing the PCB and hardwire to a better switch like proper atari type and don't connect the mode wire to the switch. It would remove the immediate dangers at least..
alexh wrote: Tue Oct 06, 2026 10:12 am]
But that has already been tried for over a year now! The owner has contacted Pavel directly several times about this, and he has not engaged.
This is how this whole thread started in the first place as theres thousands of pounds worth of dead kit which Pavel won't help with. This is why I agreed to look at the stuff to see what the chances are of repairing it all.
Pavel was also banned from this forum some time ago, mostly badmouthing others, in particular myself on various groups and platforms. Theres a rather long thread about him in the moderators section.
I feel like I'm just continuously repeating myself at this point now.
I didn't know that he had been banned. Perhaps before my time here.
I can see that you're trying to be neutral until you've analysed the failure and come to a conclusion that is supported which is commendable.
alexh wrote: Tue Oct 06, 2026 10:52 am I didn't know that he had been banned. Perhaps before my time here.
Thank you for noticing.. it is extremely difficult as a lot of people here will understand. I'm certainly giving him better treatment than he ever gave me!
HigashiJun
IIRC, Pavel was banned from this forum some time ago.
I don't feel particularly nervous, but it's wise not to use my Falcon until @exxos findouts are published on this thread.
As @rubber_jonnie suggested, I could also remove the black & white wires to prevent a flashover on my machine.
I have my new CTPSU for over a year too and it has around 50-60 power cycles until now in miscellaneous meteorological conditions. I also find quite strange the same issue happened twice to the same guy and I would like to know more about his setup and use.
HigashiJun
exxos wrote: Tue Oct 06, 2026 10:48 am Pavel was also banned from this forum some time ago, mostly badmouthing others, in particular myself on various groups and platforms. Theres a rather long thread about him in the moderators section.
You were faster than me...
HigashiJun wrote: Tue Oct 06, 2026 11:49 am I also find quite strange the same issue happened twice to the same guy and I would like to know more about his setup and use.
Not just the same guy.. 2 other people that we know of..
viewtopic.php?t=8679&start=10#p146344
viewtopic.php?t=8679&start=20#p146363
HigashiJun
exxos wrote: Tue Oct 06, 2026 11:53 am
My bad...
Completely forgot about mikro's and and kohli79's stories.
