New (and last ?) inbound
HigashiJun
Re: New (and last ?) inbound
Post by HigashiJun »
Ok, the XT CF mini is ready and flashed:
Now I have to find an 8 bit compatible CF card...
HigashiJun wrote: Sat Apr 05, 2025 9:38 am @rubber_jonnie
Indeed, the Tandy has space for three "Tandy plus" expansions.
The RAM & DMA board is a "plus" expansion, but the VGA card and the XT Cf mini are not.
Each plus expansion lays in front of its respective slot cover, but if you fit a standard ISA card you will always have the second slot unpopulated whatever you do (unless you remove the RAM & DMA card).
Since I want to keep the DMA, there is no other alternative. I can install a PICOmem instead of the VGA card, so the PICOmem will occupy the third slot, and the VGA card in the last connector but I will then have to cut the top lid to let the VGA connector out.
And as you suggest, I can try to fit the PICOmem without a bracket (that is what I wanted to do), but I'm not sure if the protruding SD card will not collide with the vertical plastic of the top lid.
I'll get some photos with a ruler so you can see the size, it may help.
HigashiJun wrote: Sat Apr 05, 2025 9:40 am Ok, the XT CF mini is ready and flashed:
Looking good.
My XT-IDE card locks up the Amstrad if I try to boot from it, trying to boot from A: doesn't work either and it's not seeing my CF cards...
HigashiJun
rubber_jonnie wrote: Sat Apr 05, 2025 9:53 am I'll get some photos with a ruler so you can see the size, it may help.
Thank you very much !
HigashiJun
rubber_jonnie wrote: Sat Apr 05, 2025 9:56 am Looking good.
Thanks.
Is your XT CF correctly flashed, and with the right BIOS ?
HigashiJun wrote: Sat Apr 05, 2025 10:19 am
Thanks.
I believe so, and it does show up at boot, it just hangs. I can make selections (A,C, F6 & F8) so the machine isn't frozen per-se, but it doesn't seem to see the CF card.
See below for PicoMEM images:
Hope they help, shout if you need anything else. I'm not trying to convince you to spend more money, but even looking at it as briefly as I have, it outperforms the XT-IDE in many ways.
HigashiJun
@rubber_jonnie
Is your CF card 8 bit compatible ?
Thanks for the pictures, they helped me a lot.
As expected, I would have to install the PICOmem in the last ISA connector (where my XT CF is fitted now) but the SD card will pop out (= have to cut out the top lid).
The PICOmem is unfortunately too wide to fit in the lower connector...
HigashiJun wrote: Sat Apr 05, 2025 11:21 am @rubber_jonnie
Glad to hear the pics helped :)
Such a shame, perhaps in the future there may be a smaller footprint version that you could use.
As for the XT-IDE I have tried various card sizes from 512MB up to 1GB and it's always stuck at the same place. Given the PicoMEM lets me effortlessly create up to 4 drives of 4GB in seconds, it was the winner.
I will try the XT-IDE again though as I want it to work now I've built it.
HigashiJun
rubber_jonnie wrote: Sat Apr 05, 2025 12:32 pm Such a shame, perhaps in the future there may be a smaller footprint version that you could use.
There is a low profile version, but the SD card is placed the same way.
HigashiJun wrote: Sat Apr 05, 2025 1:07 pm
Damn...
