TOS RAM test routine ?
Re: TOS RAM test routine ?
frank.lukas wrote: Tue Dec 06, 2022 8:35 pm 2m20s for 256MB / 4 = 35s (This is the same as the PAK020 with 40Mhz and 64MB)
Thanks for the results.
If you have not been following the thread fully, I have not yet worked out why the TTram test is faster on PAK and TOS306. It is difficult to do any tests without programming a ROM every time. Hatari needs a patch and I don't know how to do that either.
@Badwolf So this is with TP_03 enabled which should run the code in this post https://www.exxosforum.co.uk/forum/view ... =50#p95099 :shrug:
tp03.zip
(127.26 KiB) Downloaded 76 times
Just trying using an old Hatari (2.1.0) on my Mac, which switches to TT mode when TOS is names 3.09, which is fine.
ST RAM test is quick now but TT RAM test is slow.
stephen_usher wrote: Tue Dec 06, 2022 10:12 pm Just trying using an old Hatari (2.1.0) on my Mac, which switches to TT mode when TOS is names 3.09, which is fine.
I wonder if a older version on Windows would work for me.. Have a look later
stephen_usher wrote: Tue Dec 06, 2022 10:12 pm ST RAM test is quick now but TT RAM test is slow.
Thanks, not sure why STram be quicker and not TTram... will have another look.
1.9.0 Won't let me even select a TTram Value.
2.0.0 Just says bad ROM chip in E.
2.1.0 has the same problem Whereas if I force it to 306 in the header, it totally skips the RAM tests.
@stephen_usher did you try normal TOS306 in Hatari as well ? Just want to make sure its not a cache thing going on... I am assuming TOS306 is also faster than ST536 TOS ?
exxos wrote: Tue Dec 06, 2022 9:53 pm @Badwolf So this is with TP_03 enabled which should run the code in this post https://www.exxosforum.co.uk/forum/view ... =50#p95099 :shrug:
Well it's back to 4 minutes on Hatari, but bear in mind that has no concept of the RAM being faster, or the CPU going up to 50MHz.
Cache is still disabled, however. I still think that would be the biggest contributor to a faster test on real hardware.
Badwolf wrote: Wed Dec 07, 2022 10:19 am Well it's back to 4 minutes on Hatari, but bear in mind that has no concept of the RAM being faster, or the CPU going up to 50MHz.
How long does proper TOS306 take ?
exxos wrote: Wed Dec 07, 2022 10:27 am
TOS3.06 on an 8MHz TT (tried running it in ST mode -- no go) takes of the order 45 seconds.
CACR register during the test is 00003111 for TOS3. It's 00000000 for your TOS.
Badwolf wrote: Wed Dec 07, 2022 10:52 am TOS3.06 on an 8MHz TT (tried running it in ST mode -- no go) takes of the order 45 seconds.
If Hatari doesn't give any speedups for cache then its not going to be the problem for the slow down regardless of what its set at.
https://www.exxosforum.co.uk/forum/view ... =40#p95087
There must be something else different between 206 and 306 relating to the TTram tests but Ive so far not been able to work out what.
