Steve's H5 A3.14 Build (Chicken Pie edition)
Re: Steve's H5 A3.14 Build (Chicken Pie edition)
@Steve does it work ok without the gal in?
PhilC wrote: Wed Sep 01, 2021 11:25 am @Steve does it work ok without the gal in?
Just tested: same result... dbl clicking A: drive access light happens, but nothing appears and no error msg at all. I put the jumper next to the GAL in WD mode.
@Steve sounds like bad connection or something similar. I'd have a go at diagnosing it with the 68000 in and just an normal floppy.
Bothy H5s work fine as is, so gotta be something daft. You did cut the tracks near the ACSI socket didn't you?
@PhilC I've done all the mods/fixes I know about but I haven't got any cut traces near the ACSI. Perhaps you're thinking of a fix that came after my A3 version? I don't know
Steve wrote: Wed Sep 01, 2021 11:51 am @PhilC I've done all the mods/fixes I know about but I haven't got any cut traces near the ACSI. Perhaps you're thinking of a fix that came after my A3 version? I don't know
Just check this one Steve, the floppy fix
https://www.exxosforum.co.uk/forum/viewt ... 9&start=20
Yeah Phil I did that, it's on page 1 of this thread
Do I dare invoke @exxos for advice on the floppy? :shock:
Steve wrote: Thu Sep 02, 2021 12:39 pm Do I dare invoke @exxos for advice on the floppy? :shock:
I have not had much time to follow this thread, but as @PhilC Mentions, I would revisit that fix to make sure you have not got cut any of the other tracks near it or still have the original shorted to ground.
Ok will do!
Hi guys,
Just looking for some help on getting the floppy working, I really appreciate pointers on what to check.
What happens:
If I boot in 1.44mb GAL mode (JP22 on 1+2, JP18&19 open) Drive A is detected, the drive seeks on boot, drive is visable on desktop. On double clicking A the drive lights up, it makes a slight movement sound but then TOS says 'drive not responding or is damaged'.
If I boot in 720k mode (JP22 on 2+3, JP18&19 closed) Drive A is detected, the drive seeks on boot, drive is visable on desktop. On double clicking A the drive lights up, it makes a slight movement sound but then nothing happens, no message or anything.
Have tried different floppy controller chips. Have tried swapping the yamaha chip too.
Advice appreciated. I went over all the 'fixes' and they're all implemented. Perhaps @exxos may have some ideas on some continuety checks I could do? All appreciated thanks.
Return to “H5 A3 USER BUILDS”
