Yeah, wasn't expecting it to run up to me.
The Cosmic Puppet's Universe.
- Cosmic Puppet
Re: The Cosmic Puppet's Universe.
- Cosmic Puppet
Kicked in the texticles.
I've got this issue that if I cut and paste text from a word document to notepad it turns the apostrophes into weird characters.
Annoyingly. A notepad document originally typed out in notepad prints perfectly.
Wanted to just print some amended lyrics on the LC-10c while the library's shut.
Instead ending up bogged down.
Anyone know have to sort this issue? (without typing everything out again)
Use notepad++ might help. Its better anyway.
- Cosmic Puppet
Just tested and it does the same thing.
Can you send me the offending line in the word document and I will have a look ?
- Cosmic Puppet
It's every line were a word has an apostrophe.exxos wrote: Tue May 16, 2023 8:21 pmCan you send me the offending line in the word document and I will have a look ?
Do you want me to just send the document?
It's probably using a Unicode character which only looks like an apostrophe.
- Cosmic Puppet
Thanks.
This vid should explain things better:
oh, Yeah the apostrophe is not a proper one..
So in notepadd++ for example, highlight the apostrophe , Then go into the Search menu, then replace, the apostrophe you highlighted should be in the top box, and in the bottom box just put the normal apostrophe from your keyboard and click replace all.
