TF CD32 Riser Revision 2 Design Complete
TF CD32 Riser
Re: TF CD32 Riser Revision 2 Design Complete
arkadiusz.makarenko wrote: Sat Jan 02, 2021 3:33 pm Ufff. I started nervously biting my nails :D
There is an issue.
Something between the TF accelerators and the riser is resulting in the reset line being held low. every now and again it pops out of that mode but i can for sure see the reset lines held low..
Is reset from the riser floating when not set?
EDIT: also sysinfo with the TF360 reports 21 instead of 70.. so defo some performance left of the table.
arkadiusz.makarenko
Post by arkadiusz.makarenko »
terriblefire wrote: Sat Jan 02, 2021 3:54 pm
There is an issue.
I have KBD_Clock set up for Open Drain, and I pull it low when required.
But On STM32 startup I have moment when keyboard do the reset?
~ Stanislaw Lem
arkadiusz.makarenko wrote: Sat Jan 02, 2021 4:09 pm
There is an issue.
yeah for some reason its not coming out of that. I had an older version of the firmware i hacked that ran the keyboard reset to the motherboard right at the moment the arm boots. and that worked really well.
CD32 reset setup is the worst of any amiga btw.
arkadiusz.makarenko
terriblefire wrote: Sat Jan 02, 2021 4:12 pm
I have deeply modified keyboard routine to avoid long blocking delays. Maybe I am sloppy somewhere with setting modes or there are empty sends triggeredby timer.
With performance, there is still some room for improvement I guess, but I don't think it will match 1:1.
~ Stanislaw Lem
I think for the keyboard you can block all day because its clocked. It doesnt matter if the CPLD interrupts.
arkadiusz.makarenko
terriblefire wrote: Sat Jan 02, 2021 4:44 pm I think for the keyboard you can block all day because its clocked. It doesnt matter if the CPLD interrupts.
my main loop routine manages registeres and usb hid report decode etc. Plus If I ever look at FlashFloppy or soundcard like 10ms (?) waits between each key send seemed as waste of resources.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Sat Jan 02, 2021 4:51 pm
Ah fair enough. I need to dig into what is holding the reset line low.
arkadiusz.makarenko
terriblefire wrote: Sat Jan 02, 2021 4:55 pm
KBD_Clock is on Port B the same as Data lines, so maybe mode is being changed for this pin during bus data write?
I will have a look at this hopefully tonight.
~ Stanislaw Lem
Just FYI..
here is the times you're getting
arkadiusz.makarenko
Could you check this? @terriblefire
There are two changes, KBD_Clock is fixed to one setting Open Drain and never reconfigured. I checked on datawrites and seems to be ok.
second change is simple optimization -OFast insead of -ODebug maybe speed will be a little but better?
TFRiserRev2F722.zip
(21.52 KiB) Downloaded 227 times
~ Stanislaw Lem
Return to “TF CD32 Riser”
