HigashiJun
Post by HigashiJun »
rubber_jonnie wrote: Wed Feb 12, 2025 9:17 am Annoyingly Moonfish & Sunfish are asking for some packages that I'd already installed, so I think my last backup might have been missing some changes :(
Wouldn't it be simpler with FTPc ?
Moonfish and Sunfish were a real PITA and memory hungry. I gave up quickly...
HigashiJun wrote: Wed Feb 12, 2025 11:09 am
For sure.
I think the server (Sunfish?) was less hungry than the other, but still not good.
I tried really hard to get FTPc to work, but just couldn't. This may be an opportunity to try again. I also tried LanMan98 but that wouldn't connect to any of my windows machines either.
HigashiJun
rubber_jonnie wrote: Wed Feb 12, 2025 11:50 am I tried really hard to get FTPc to work, but just couldn't. This may be an opportunity to try again. I also tried LanMan98 but that wouldn't connect to any of my windows machines either.
Once everything was set correctly, it was really easy peasy to connect to my shared storage.
I do however agree that it's more complicated for ACORNs, and there's also a lack of clear information.
HigashiJun wrote: Thu Feb 13, 2025 6:57 am
It's really odd, I'm sure I had Sun/Moonfish all sorted and the necessary parts installed. I was trying FTPc again, but one version is asking for acornssl which I can't seem to find and the other starts fine but any ftp connection attempt doesn't even seem to leave the machine.
HigashiJun
@rubber_jonnie
That's weird...
Is your Ethernet podule driver set correctly ?
I had to tweak 2 or 3 settings in a config file before I could connect to my network drive.
HigashiJun wrote: Thu Feb 13, 2025 10:38 am @rubber_jonnie
That's weird...
Were they settings for FTPc? Or the NIC?
I can ping anything I want no problem, even on the internet, but when I try to connect over FTP with FTPc I don't see a single packet arrive at the FTP server when I try to connect, and it isn't blocked I can connect from my laptop on FTP. Very odd, it's like FTPc has no network connection.
HigashiJun
@rubber_jonnie
For the NIC.
But if you are able to ping, then everything should be set as it should.
Check for reference the following picture:
https://www.exxosforum.co.uk/forum/view ... 10#p122681
I remember I had issues with the PATH setting.
HigashiJun wrote: Thu Feb 13, 2025 11:13 am @rubber_jonnie
For the NIC.
Cool, thanks.
BTW did you need to install acornssl to use FTPc? If so where did you get it from please?
HigashiJun
@rubber_jonnie
No, I didn't install acornssl.
I guess it's not loaded in the ROM of the NIC either, but I have to check.
HigashiJun wrote: Thu Feb 13, 2025 12:29 pm @rubber_jonnie
IIRC the NIC I have doesn't have a ROM.
