Apples aren't the only fruit.
Re: Apples aren't the only fruit.
Other than patience?
12mm x 6mm thick open foam tape, mylar emergency warmth blanket, a 11mm open hole punch, hammer to punch the mylar along with a block of wood, a cutting board to cut the foam on, a pad to prevent the punch damaging your hand as you use it to cut the foam and some PVA glue.
The foam would be better if it were 4mm thick as 6mm is too close to having contact all the time but 6mm was thinnest I could get with as 12mm wide strip.
Quite the procedure then!!stephen_usher wrote: Mon Mar 04, 2024 9:38 pm Other than patience?
Nice work.
- HigashiJun
Hope it will do the job.
The keys I've already done seem to work fine, but I've not tried it with the keyboard screwed together and hence with a smaller tolerance between the foil and the PCB. It could be that it's like all the keys are being pressed at once!
That set of 32 pads fitted, all working. 29 more to go!
stephen_usher wrote: Tue Mar 05, 2024 9:17 am That set of 32 pads fitted, all working. 29 more to go!
Miscounted, it was 32.
Anyway, during the time it's taken waiting for the AA to turn up (called at 8:40 am with an initial ETA of 9:40am but now 11:20am) I've been able to manufacture those last 32 pads. I'll let the PVA dry for a bit before fitting them, testing and then reassembling the keyboard.
Good stuff.stephen_usher wrote: Tue Mar 05, 2024 10:45 am Miscounted, it was 32.
I take it the AA is for the BMW? Hope they can get it sorted. I have to say when my wife called them last week they got there within the hour.
Fingers crossed that the keys don't all make contact when you reassemble the keyboard.
Yeah it's for the BMW. Seeing as I'm a low priority (safe position, at home etc.) I can understand why my call would be pushed back a bit but only to a certain point.
Yeah, to be fair my wife was stuck in a hospital car park with her partially deaf/blind Dad, so kudos to them for bumping it up for her.stephen_usher wrote: Tue Mar 05, 2024 10:55 am Yeah it's for the BMW. Seeing as I'm a low priority (safe position, at home etc.) I can understand why my call would be pushed back a bit but only to a certain point.
Do the AA carry such things as springs these days? It's quite a job to replace, I know from personal experience of doing one on my wife's C3. That was a long time ago thinking about it!!
