ACORN A5000 inbound
HigashiJun
Re: ACORN A5000 inbound
Post by HigashiJun »
Guess what..
It lives !
I just fit the battery in its holder and connected it to the motherboard, reset the RTC and set the monitor.
:D
Yay! :girldance:
HigashiJun
stephen_usher wrote: Thu Nov 30, 2023 8:23 am Yay! :girldance:
:cheers:
Woo-hoo!!!
:girldance: :girldance: :girldance:
Awesome. Does the IDE work?
HigashiJun
rubber_jonnie wrote: Thu Nov 30, 2023 9:28 am Woo-hoo!!!
:cheers:
HigashiJun
alexh wrote: Thu Nov 30, 2023 9:59 am Awesome. Does the IDE work?
Thanks.
The IDE is not tested yet, as 3 or 4 tracks are still to be repaired before I can fit the second buffer.
HigashiJun wrote: Thu Nov 30, 2023 10:15 am
Thanks.
The IDE is not tested yet, as 3 or 4 tracks are still to repair before I can fit the second buffer.
Don't forget the IDE supports a limited number of drives unless you use something like Wizzo, mine is just a 128MB IDE flash drive, I use SCSI for most stuff.
You'll need !hform IIRC to prep any IDE drives you want to use.
HigashiJun
Just one pic for today:
These two tracks were to close to have a bare wire fitted, so I preferred an insulated one.
Anyway, it will be barely visible once the IDE and FDD connectors fitted.
As stated in the previous post, some tracks are still to be repaired and a buffer is still to be soldered.
I don't know why, but I feel motivated.
:lol:
HigashiJun
rubber_jonnie wrote: Thu Nov 30, 2023 10:23 am Don't forget the IDE supports a limited number of drives unless you use something like Wizzo, mine is just a 128MB IDE flash drive, I use SCSI for most stuff.
Yes, the onboard IDE is somehow limited...
I plan to get myself a ZIDEFS IDE, and I already have the special !hform.
