Steve,
So far, the fan still works fine, so I was not planning to replace it. However, in the event I find it necessary to replace the fan, is there a recommended fan that can replace the current fan and not fall into the category of low-speed fan?
I appreciate you bringing up the fan, I will be careful in searching for a compatible, high-speed fan, should I need a new one.
Thank you.
Randy
TT030 Reset Issue
Re: TT030 Reset Issue
@MacTech05 the following thread should provide you with all the information you need: https://www.exxosforum.co.uk/forum/view ... 37#p101378
