Whoops I did it again - Sega Saturn inbound
Re: Whoops I did it again - Sega Saturn inbound
PhilC wrote: Thu Dec 08, 2022 10:43 am
alexh wrote: Thu Dec 08, 2022 10:24 am If you really want to "mod" your saturn you could fit a region free BIOS? That was the hardest thing I've ever soldered. Oh for hot air!
I'm not sure you need region free BIOS anymore? But I don't know how many hoops you have to jump through for region free via cartridge.
I also fitted a 50Hz/60Hz switch to mine, simple metal switch.
That Cartridge I've linked to does the region free bit too and is pretty simple to fit :)
Not decided on any mods as yet (I actually recently de modded my OG Xbox), but I do like the look of that cart @PhilC
PhilC wrote: Thu Dec 08, 2022 10:07 am @rubber_jonnie That battery will take you all of five seconds to do, it's a CR2032 IIRC.
The mod chips are about £25 on Aliexpress and I have one of these too which makes things even better
https://www.aliexpress.com/item/3298778 ... 7Rcvvgwa31
Just ordered the cartridge :) Typical Ali Express though, you can forget about any express delivery, will be here in January!!
@rubber_jonnie cool, now you just need to find some Cdr's that work with it :D I use Maxell if it helps :) and I think CDRomance for the images.
PhilC wrote: Thu Dec 08, 2022 12:29 pm @rubber_jonnie cool, now you just need to find some Cdr's that work with it :D I use Maxell if it helps :) and I think CDRomance for the images.
Sweet, thanks for the tips. Just got Sega Rally for it for £4.99 :) Be good to compare to the Dreamcast version.
@rubber_jonnie it's a bit blocky but Sega Rally chugs along nicely on it
PhilC wrote: Thu Dec 08, 2022 2:35 pm @rubber_jonnie it's a bit blocky but Sega Rally chugs along nicely on it
Cool :)
atari030
Post by atari030 »
Probably the best Sega game ever. Loved it on the DC.
Higgy
Post by Higgy »
Sega Rally 1 (not remake) on the PS2 is excellent. Japan only release, but quite easy to get it to run nowadays.
I don't think it supports steering wheels though, well not Logitech.
Well, Sega Rally is on the way and I'm watching a Daytona: USA auction, so all good.
As I said earlier, I ultimately want to get a Fenrir, but for now it's got to wait until the new year. I also want the DC equivalent and an Everdrive or similar for the SNES. Going to be an expensive year 2023 :dizzy:
Th DC Gmecu or whatever it's called is actually pretty cheap, around £40 with the 3d printed parts to adapt the case. I got mine from Aliexpress.
