TOS RAM test routine ?
Re: TOS RAM test routine ?
I guess if someone fancies looking at the memory test routines, it could be possible to just copy the routine to run from TTram instead. Of course it would have to test a small memory area is valid before copying the routine to it. But if it is switching to 8MHz to run the test then ramping up to 50MHz would go lightning fast.
Here's TOS206.img.exxos wrote: Tue Dec 06, 2022 3:09 pm @Badwolf When you get a moment can you please give this one a try. I tried only altering the number on the TTram test..
Looks like the inverse video is gone again.
The ST-RAM test finishes early.
The TT-RAM test seems faster, but with the ST-RAM finishing early, I don't know if it's legit.
For comparison, here's the (slow) TP32.img with all the same settings.
Thanks. I think I will just abandon making the test faster because I don't know currently what PAK TOS did to speed it up.Badwolf wrote: Tue Dec 06, 2022 7:16 pm For comparison, here's the (slow) TP32.img with all the same settings.
Well the first one looks to be about twice as fast to me, but I reckon you'd do better just to turn on the instruction cache (although like Doug says, that won't show up on Hatari). The CACR is 0000 during these tests (according to the debugger). That just needs to be changed to 0001. Presumably something sets them to something sensible later after the tests so it shouldn't be a problem.exxos wrote: Tue Dec 06, 2022 7:32 pm Thanks. I think I will just abandon making the test faster because I don't know currently what PAK TOS did to speed it up.
Try bunging
move.l #$00000001,d0
D0_CACR
I can see if it's made the change in Hatari, but it'd need testing on real hardware to know if cache has really helped.
EDIT: although, TBF, who really minds if a memory test everyone skips is a bit slow?
Yeah, it is much time messing about just for the sake of someone pressing spacebar.Badwolf wrote: Tue Dec 06, 2022 8:01 pm I can see if it's made the change in Hatari, but it'd need testing on real hardware to know if cache has really helped.
EDIT: although, TBF, who really minds if a memory test everyone skips is a bit slow?![]()
I don't know why the inverse video comes up. does not seem to be related to anything I changed as I reversed all the changes.
PAK/3 TOS 3.06 is approximately the same speed as TOS 3.06 on the TT, so it's not the PAK/3 changes.
Thats a point.. I altered that tosversion thing as well.. That could be what is sitting the inverse video.stephen_usher wrote: Tue Dec 06, 2022 8:12 pm PAK/3 TOS 3.06 is approximately the same speed as TOS 3.06 on the TT, so it's not the PAK/3 changes.
Yep this was the cause..
#if TOSVERSION >= 0x300
move.l d0,-(a7)
movea.l #memtsp,a0
bsr mempstr
move.l (a7)+,d0Re: TOS RAM test routine ?
@frank.lukas - GERMAN ST536 TOS.
@Badwolf
Oddly it seems to be hellbent on actually disabling them more than anything
hmmm..
So this is actually turned off because TP_50 = 1 in the defs file..
No idea what this is doing ?
Looks like a totally new bank of routines for testing ROM CRC and RAM as its got the same $20000 value in there.
Looks to be triggered from TP_03
* disable the instruction/data caches
#if (TOSVERSION >= 0x300) | TP_50
data
zero:
dc.l 0
text
#if TP_50 /* PAK */
lea no020(pc),a0
move.l a0,(_illinst).w
#endif
move.l #$00000808,d0 /* clear & disable instruction/data caches on */
D0_CACR /* 68020-60 (even though bit usage differs!) */
moveq #0,d0
D0_VBR /* initialise VBR to zero */
no020:EDIT:
hmmm..
#if TP_03 /* RAMRESET */
#include "../tospatch/ramres.S"
#else
#if (TOSVERSION >= 0x300) & (TOSVERSION < 0x400) & !TP_50
btst #0,(scu_gp1).w
beq.s domemchk
#endifCode: Select all
lea reset(PC),A6
bra memchk
newkres: move #$2700,SR /* disable interrupts */
clr.l (_memvalid).w /* make memory configuration invalid */
movea.l 4.w,A0
lea (_buserror).w,A1
moveq #(($0100-$0008)/4)-1,D0 /* clear $8-$100 */
newkres1: move.l A0,(A1)+
dbra D0,newkres1
bra _main
resethandler: cmpa.l #resetvec,A6
beq.s noreset
lea _main(pc),a6
crc: lea _os_entry(PC),A3 /* start address */
lea rom_crc_table,A1
moveq #numbanks-1,D7
crc0: move.l #banksize,D2 /* bytes to check per loop */
moveq #0,D0 /* set starting values */
moveq #0,D5
movea.l A3,A0
crc1: move.w (A0),D3
addq.l #numbanks,A0
move.w D5,D6
lsl.w #8,D5
lsr.w #8,D6
eor.b D3,D6
add.w D6,D6
move.w 0(A1,D6.w),D4
eor.w D4,D5
move.w D0,D1
lsl.w #8,D0
eor.w D3,D1
lsr.w #8,D1
add.w D1,D1
move.w 0(A1,D1.w),D4
eor.w D4,D0
subq.l #1,D2 /* already done? */
bne.s crc1 /* no => */
move.w (A0),D1
move.b D1,D6
addq.l #numbanks,A0
move.b (A0)+,D1
cmp.w D1,D0
bne.s oldkeyresetj
lsl.w #8,D6
move.b (A0),D6
cmp.w D6,D5
oldkeyresetj: bne coldboot
addq.l #2,A3 /* 2 passes */
subq.l #2,D7 /* again? */
bpl.s crc0 /* yes */
jmp (A6)
reset: beq go_on
lea checkmem(PC),A6
bra.s crc
checkmem: lea ($00007FFE).w,SP
movea.l (_buserror).w,A4 /* save buserror vector */
move.l #coldboot,(_buserror).w /* set new vector */
lea _os_entry(PC),A2 /* set end address */
move.l #$00020000,D7 /* distance of probes */
movea.l D7,A0 /* set start address */
move.w #$FB55,D3 /* value to add */
loop1: movea.l A0,A1
move.w D0,D2
moveq #$2A,D1
loop2: move.w D2,-(A1)
add.w D3,D2
dbra D1,loop2
movea.l A0,A1
moveq #$2A,D1
loop3: eor.w D0,-(A1)
bne.s oldkeyresetj
add.w D3,D0
dbra D1,loop3
adda.l D7,A0
cmpa.l A2,A0
bls.s loop1
movea.l A2,A0
move.l A4,(_buserror).w
movem.l (A1),D0-D7/A1/A3-A6 /* get zeroes */
clrmem: movem.l D0-D7/A1/A3-A6,-(A0) /* clear page */
movem.l D0-D7/A1/A4-A6,-(A0)
cmpa.w #$0100,A0 /* clear memory to $100 */
bhi.s clrmem
move.l A2,(_phystop).w /* highest address as phystop */
move.l #$752019F3,(_memvalid).w
move.l #$237698AA,(_memval2).w
move.l #$5555AAAA,(_memval3).w
clr.l (_ramtop).w
move.l #$1357BD13,(_ramvalid).w
move.b (memctrl).w,(memconf).w
go_on: move.l #$31415926,(resvalid).w
move.l #resethandler,(resvector).wLooks to be triggered from TP_03
TP_03: RAMRESET: Modified reset routine.
* Will keep RAM-TOS resident even after Hardreset (via keyboard)Code: Select all
# Set this to 1 to build a RAM version relocated to 0x380000.
# Only the PL version uses this so far.
# Note that the PL version is not an official TOS, it is
# an image found on the net on several sites, and contains
# some patches for the BIOS.
RAMVERSION=0- frank.lukas
Many thanks ...
2m20s for 256MB / 4 = 35s (This is the same as the PAK020 with 40Mhz and 64MB)frank.lukas wrote: Mon Dec 05, 2022 6:40 pm Fastram bar only ...
PAK030/50Mhz 64MB = 24s
PAK020/40Mhz 64MB = 35s
TF536 /50Mhz 64MB = 4m40s
... the ST Ram test bar is faster on the PAK Atari ST than on the TF536 Atari ST.
Atari TT 32Mhz 256MB = 2m20s
... the PAK machines are already faster than the Atari TT.
