exxos wrote: Sat Feb 13, 2021 10:55 am
HigashiJun wrote: Sat Feb 13, 2021 10:30 am
As for now, I did not revert to originals SILs and still have the 2.2 K ones soldered in.
You should remove the MB ones as you will have 1.1K pullups in total , I found that can cause DMA issues on some machines.
No need either to use the 22uf capacitor in case the machine refuses to boot.
You still need it, or recap the reset circuit...
Just funny to see that Sysinfo reports the CPU speed as 10 Mhz...
Not surprised, effective speed, like 20% I guess overall. But ROM will work at much higher speeds, so desktop and apps will fly!
Sure, if I spot any glitches, I will apply these little tweaks, but as for now, no reason to do so.
I have the last DMA chip, so I might have no issues at all.
- DMA.jpeg (462.59 KiB) Viewed 6537 times
For this first test, everything works great.
I will keep you informed later on.
Thank you for this great piece of hardware Exxos !
