TF CD32 Riser Revision 2 Build Guide.
TF CD32 Riser
arkadiusz.makarenko
Re: TF CD32 Riser Revision 2 Build Guide.
Post by arkadiusz.makarenko »
alenppc wrote: Sun Feb 21, 2021 9:23 pm Thanks, will test and report back (probably tomorrow).
After work I will prepare source code for bugfixes.
So I will be able to compile some stuff for tests.
~ Stanislaw Lem
alenppc
Post by alenppc »
Ok, I tried version 1.0 and there is no difference in mouse behaviour. It works correctly on 060 only but not on 030/020. For completely crazy behaviour, try clocking your 030 at 40 mhz and watch everything go wild.
arkadiusz.makarenko
alenppc wrote: Sun Feb 21, 2021 10:48 pm Ok, I tried version 1.0 and there is no difference in mouse behaviour. It works correctly on 060 only but not on 030/020. For completely crazy behaviour, try clocking your 030 at 40 mhz and watch everything go wild.
I will order 80mhz crystal.
~ Stanislaw Lem
arkadiusz.makarenko
alenppc wrote: Sat Feb 20, 2021 3:40 am Logitech M325c doesn't work at all, and the mouse that glitches is the Rapoo 3360 (works best with Risermouse 1). But those are literally the only two I tried so far. I tried a generic USB keyboard and that seems to work without any issues. Apple keyboard doesn't. Will try more when I get a chance. Thanks for all the work you have done so far.
I can confirm that Rapoo 3360 works fine on my Riser and Amiga, so it is the same issue like any other glitching mouse.It is ARM<->Amiga communication.
PS.
This mouse is tiny!
~ Stanislaw Lem
alenppc
Post by alenppc »
arkadiusz.makarenko wrote: Mon Feb 22, 2021 6:22 pm This mouse is tiny!
Haha, this is what my wife bought me when I told her my old mouse was broken. :lol:
arkadiusz.makarenko
I have added few delays - It is just to check if this helps.
It always works on my setup, so I can't reproduce it just now. I think TF328 would be the best for tests.
TFRiserRev2F722.zip
(21.18 KiB) Downloaded 166 times
!Message from: Moderator
@arkadiusz.makarenko, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
~ Stanislaw Lem
alenppc
Post by alenppc »
No real difference compared to the last one. On 020 the mouse still won't move sideways. Same as before on 030.
arkadiusz.makarenko
alenppc wrote: Mon Feb 22, 2021 7:03 pm No real difference compared to the last one. On 020 the mouse still won't move sideways. Same as before on 030.
So this is not a matter of timings on ARM side.
~ Stanislaw Lem
arkadiusz.makarenko
I have changed few tiny bits in CPLD.
You can try those.
main_top.zip
(6.19 KiB) Downloaded 174 times
~ Stanislaw Lem
alenppc
Post by alenppc »
There seems to be a teeny-tiny improvement, as in reduced phantom movements on 030 and slightly more horizontal movement on 020.
Return to “TF CD32 Riser”
