TRUDIE V5.2 (5 volt) pre-release install guide
IDE, ACSI etc kits and products.
DoG
Re: TRUDIE V5.2 (5 volt) pre-release install guide
Post by DoG »
JezC wrote: Wed Mar 09, 2022 5:51 pm...
I've got my TRUDIE v5.2 plugged into my H4 & appears to be working fine...but how do I change the ROM image selection (bottom/top or top/bottom) now the TRUDIE is installed?...
It should still be the jumper on the mommy board. Trudie is only a decoder for 256K roms to another address (well, IDE as well of course ;) ).
@JezC No time to break things at the moment, feel free to steal my job :P
Post by JezC »
DoG wrote: Wed Mar 09, 2022 6:31 pm
Thx @DoG - I'll try it shortly!
Post by JezC »
PhilC wrote: Wed Mar 09, 2022 6:44 pm @JezC No time to break things at the moment, feel free to steal my job :P
:lol: Ok, though with any luck I'll leave it open for you to reclaim at any point ;)
Post by JezC »
JezC wrote: Wed Mar 09, 2022 10:14 pm
Ok, moving the jumper didn't work first time... :blonde: ...so after I removed it a second time (and found & removed the stray wire shorting the pins) it booted into the EmuCON command line.
Which shows it is now working...but that I have an EPROM in there with the custom EmuTOS floppy loader rather than TOS 2.06 or EmuTOS programmed into it.
So, job for later is to erase an EPROM & then program it up with TOS 2.06 (and maybe EmuTOS 256k after that)...
Post by JezC »
JezC wrote: Wed Mar 09, 2022 10:15 pm
Managed to find & fix a previously undiscovered build problem with my assembled H4 without breaking it! :yay: :yay2: :dualthumbup: :cheer:
Now to see if I can change that EPROM for TOS 2.06 and/or EmuTOS...then get the TF536 you provided running in the H4 again...
Return to “HARD DRIVES”
