Atari ST keyboard interface.
- arkadiusz.makarenko
- Moderator Team
Re: Atari ST keyboard interface.
Got the issue, mixture of updates to stm32 libraries, plus bug in usb stack (some devices don't work correctly in boot mode).
~ Stanislaw Lem
~ Stanislaw Lem
- Moderator Team
Do you think it is worth to resurrect this project?
Goal would be £5 or under in parts + usb hub.
Target MPU RISC-V based budget chip (CH32V203C)
Since I did learn how to use KiCad I can at last do my own PCBs which was main stopper for this kind of projects?
~ Stanislaw Lem
~ Stanislaw Lem
Hi @arkadiusz.makarenko I'd certainly be interested in this project (and not just for alternatives to the real ST keyboards, but also because we use lots of ARM cores at work, so seeing how a RISC V part compares would be very informative).
I'd be happy to help test if/when you are ready...
Does you implement a full HD6301 emulator or it works at the IKBD level?
Note that for full compatibility you need HD6301 emulation.
http://pasti.fxatari.com
- Moderator Team
I wasn't looking at HD6301 emulation, but USB HID keyboard gamepads and mouse implementation.ijor wrote: Wed Dec 20, 2023 12:20 am Does you implement a full HD6301 emulator or it works at the IKBD level?
~ Stanislaw Lem
~ Stanislaw Lem
I see. Some software will not run. A few games and demos require HD6301 emulation. Depending on your goals, you might not care since it is a small minority. But you should probably be aware.arkadiusz.makarenko wrote: Wed Dec 20, 2023 6:36 am I wasn't looking at HD6301 emulation, but USB HID keyboard gamepads and mouse implementation.
- Moderator Team
Yes, I am aware of it.ijor wrote: Wed Dec 20, 2023 4:01 pmI see. Some software will not run. A few games and demos require HD6301 emulation. Depending on your goals, you might not care since it is a small minority. But you should probably be aware.arkadiusz.makarenko wrote: Wed Dec 20, 2023 6:36 am I wasn't looking at HD6301 emulation, but USB HID keyboard gamepads and mouse implementation.
Amount of work required to implement it would be massive overkill.
There is probably enough memory and computing power to do it, but this would take me ages to write and ages to debug.
~ Stanislaw Lem
~ Stanislaw Lem
There are open source implementations, if you are interested.arkadiusz.makarenko wrote: Wed Dec 20, 2023 5:33 pm Amount of work required to implement it would be massive overkill.
- Moderator Team
Yes, I can have a look.ijor wrote: Wed Dec 20, 2023 8:12 pmThere are open source implementations, if you are interested.arkadiusz.makarenko wrote: Wed Dec 20, 2023 5:33 pm Amount of work required to implement it would be massive overkill.
~ Stanislaw Lem
~ Stanislaw Lem
STeem SSE, a very popular ST emulator for Windows, includes HD6301 emulation:
https://sourceforge.net/p/steemsse/code ... arty/6301/
I understand it is based on third party code. I'm not sure what was modified in Steem.
I think there is also an ARM MCU based project with HD6301 emulation, but can't find it right now.
