kludge’s TF534 build
- Admin sponsor
Re: kludge’s TF534 build
I can try a ZII firmware for you guys but TBH the machine will not boot if i do that. You have a ram problem.
You need to add the address range 0x40000000 to 0x40400000 to the system pool somehow. I usually use AddMem but it doesnt work on Kick 1.3
I could give you a firmware where the ram doesnt autoconfig but appears in the above location. Then it would at least let you use addmem etc.
- 8 Bit Dreams
- Moderator Team
i can provide You 1.3 KS with scsi.device installed if that help, but this will not solve ZorroIII RAM Problem though..
You need to figure out why Your Amiga boots with KS 1.3 (256kb rom) and rejects to with KS3.1 (512KB),
onboard RAM failure can be a reasion fot that.. In other words - You need to remove all expansions and make Your Miga work (with all Kickstart versions) Then move 1 step forward..
Ok... DiagROM fails the chipmem test on the A500 with the 68000 installed, but Workbench 3.1.4 boots from floppy without issues.
On the A500+ Diagrom shows a red screen briefly (checksum error?), but memory tests are good as far as I can tell. But with the TF534 installed it's the exact same problem as with the A500 on KS 3.1.4.
BTW. I'm using this: https://github.com/terriblefire/terribl ... _alpha.zip
Maybe I should have started out by mentioning that?
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
- 8 Bit Dreams
- Moderator Team
Workbench may boot in area that is not affected, THIS DOESN'T MEAN ANYTHINGkludge wrote: Wed Mar 27, 2019 9:17 pm Ok... DiagROM fails the chipmem test on the A500 with the 68000 installed, but Workbench 3.1.4 boots from floppy without issues.
does this mean, You have two Amigas: A500 & A500+, while A500+ doesn't even boot with DiagRom?kludge wrote: Wed Mar 27, 2019 9:17 pm On the A500+ Diagrom shows a red screen briefly (checksum error?), but memory tests are good as far as I can tell. But with the TF534 installed it's the exact same problem as with the A500 on KS 3.1.4.
this is Firmware pack? seems ok to me, using same binarieskludge wrote: Wed Mar 27, 2019 9:17 pm BTW. I'm using this: https://github.com/terriblefire/terribl ... _alpha.zip
Maybe I should have started out by mentioning that?![]()
Yes, A500 and A500+. A500 and A500+ boots with the 68000, but DiagROM shows a red screen briefly at the beginning with A500+, but then starts as normal.8 Bit Dreams wrote: Wed Mar 27, 2019 9:35 pm does this mean, You have two Amigas: A500 & A500+, while A500+ doesn't even boot with DiagRom?
The 500 and the 500+ behave the exact same way with the TF534 trying to boot 3.1.4. Blinking power LED and resets every 7-8 seconds.
True, but KS 3.1.4 fails to do anything with the TF534 (on both machines, as well as on the A600, but that's for another day), but boots Workbench with the 68000. If the Amiga(s) was the main problem, shouldn't I get the same issue without the TF534?8 Bit Dreams wrote: Wed Mar 27, 2019 9:35 pm Workbench may boot in area that is not affected, THIS DOESN'T MEAN ANYTHING
I'm not trying to argue, just to understand.
My lack of focus:
My lack of focus:
If I blank the RAM CPLD, would the card work at all? I understand I wouldn't get RAM (or IDE), but at least it could help narrow it down if 3.1.4 would boot then.terriblefire wrote: Wed Mar 27, 2019 8:50 pm I can try a ZII firmware for you guys but TBH the machine will not boot if i do that. You have a ram problem.
My lack of focus:
My lack of focus:
- Admin sponsor
Unsure. There's a lot of chat between the two CPLDS.kludge wrote: Wed Mar 27, 2019 9:53 pmIf I blank the RAM CPLD, would the card work at all? I understand I wouldn't get RAM (or IDE), but at least it could help narrow it down if 3.1.4 would boot then.terriblefire wrote: Wed Mar 27, 2019 8:50 pm I can try a ZII firmware for you guys but TBH the machine will not boot if i do that. You have a ram problem.
- 8 Bit Dreams
- Moderator Team
ok, thanks for explanation, wasn't aware You have two Amigas, actually three if we cout A600 too, so well... Seems something is wrong with Your TF534 build. Do You have microscope? It's really really needed if it comes to debugging, trust me, i've built over 100x TF530, there so tiny bridges, and cold solder joints - You barely see them with microscope.
If You don't have one - well, try to resolder:
1. RAM cpld
2. RAM itself
3. 74ac16245 inverter
or make good and sharp high resolution pictures and upload them somewhere, maybe we will find something suspicious..
1. RAM cpld
2. RAM itself
- Admin sponsor
If the 74AC16245 didnt work the CPU wouldnt boot diagrom. You can leave that alone i think.8 Bit Dreams wrote: Wed Mar 27, 2019 10:06 pm ok, thanks for explanation, wasn't aware You have two Amigas, actually three if we cout A600 too, so well... Seems something is wrong with Your TF534 build. Do You have microscope? It's really really needed if it comes to debugging, trust me, i've built over 100x TF530, there so tiny bridges, and cold solder joints - You barely see them with microscope.
1. RAM cpld
2. RAM itself
or make good and sharp high resolution pictures and upload them somewhere, maybe i will find something suspicious..
The A500+ is a very recent acquisition8 Bit Dreams wrote: Wed Mar 27, 2019 10:06 pm ok, thanks for explanation, wasn't aware You have two Amigas, actually three if we cout A600 too, so well... Seems something is wrong with Your TF534 build. Do You have microscope? It's really really needed if it comes to debugging, trust me, i've built over 100x TF530, there so tiny bridges, and cold solder joints - You barely see them with microscope.
1. RAM cpld
2. RAM itself
I have a USB microscope as well as other magnifying options. I have checked, but I will check again tomorrow. And tomorrow I will hopefully get my new soldering station with hot air and preheater, so I could go over it with that. Or even desolder the chips and put them back on. (Practicing on a TF534 is a great plan, right?
It would be interesting to know what it is that DiagROM misses in this case.terriblefire wrote: Wed Mar 27, 2019 10:12 pm If the 74AC16245 didnt work the CPU wouldnt boot diagrom. You can leave that alone i think.
Unless I have two Amigas with different weird issues that causes the same problem with original kickstarts when running the accelerator.
My lack of focus:
My lack of focus:
