Soldering is easy but the the software stuff and how it works on the amiga side is not my strongest thing.
TF1230 Beta Interest (Open Source)
Re: TF1230 Beta Interest (Open Source)
Thank you supaduper
I understand allot more after reading your perfect guide. Now I have something to do the next week.
Thank you superduper for a great guide, just trying to do a custom 3.1 build in winuae & I run out of space for ehide.device
That guide is for rom 3.2, if you are doing a custom 3.1 then I do mention that you `REMOVE` the Workbench.library from the build List, make sure that you then manually replace the Workbench.library back into Libs on the System disk otherwise it will not work
Download Workbench Library here:
http://www.amigaforever.com/classic/download/
I soldered to my Amiga rev. 2B TF1230.
CPLD144-10ns, RAM MT48LC16M16A2P-6A, Digital bus switch SN74CB3Q3245PWR, i.e. the systems I used in TF536.
Programmed CPLD -
tf1230r1_2021_09_14_RC1.zip
I tested WHDLOAD games
Tested by internal IDE 1200 and works fine.
I tested EHIDE.DEVICE driver and IDE controller on TF and whdload does not work properly.
He's not fully uploading the game, they're going through the intro and still don't want to upload.
It happens that during the game he has to play something and he does not do it.
Someone can check it if this is the case.
Programmed CPLD -
- Admin sponsor
Which games. We need a little more information. Also try the later beta.dragmar wrote: Wed Oct 06, 2021 9:47 am I tested EHIDE.DEVICE driver and IDE controller on TF and whdload does not work properly.
OS32, WHDLOAD 18.5
lure of the temptress, ishar
markus0321
Try to run MuFastROM from the MMU_libs package from aminet before loading the game. For me, when I run FastROM, the problems with ehide disappear, if I leave it in the ROM memory, it is unstable.dragmar wrote: Wed Oct 06, 2021 9:47 am I soldered to my Amiga rev. 2B TF1230.
Programmed CPLD -
I have a similar problem with WHDload 18.5 & Dragon Tiles AGA on my TF1260 and the original firmware. Everything else works really well
ehide.device loaded at the beginning of startup-sequence, MuFastROM called from user-startup. I didn't really investigate since the DoM I use won't fit under my keyboard, just went back to the internal IDE and enjoying the rest of the card.
a caffeine addict and known hater of mornings that answers to either Andrea or fluffkitten
Avinitlarge
Which are the best ram chips to use for 128mb? I’ve seen a few different ones mentioned.
- 8 Bit Dreams
- Moderator Team
terriblefire wrote: Thu Sep 30, 2021 9:00 am <Snip>
Issi "IS42S16320F-7TL" for 128MB: Everything works perfect in all circumstances without errors in WHDLoad.
<Snip>
