Careful or you will end up like I did, trying to route the whole board
exxos blog - random goings on
Yeah, got a month, so probablyIcky wrote: Fri Oct 04, 2019 1:13 pm Careful or you will end up like I did, trying to route the whole board![]()
Doing a bit more routing, but its at the point where its starts getting really complicated now. I'm ripping up sections I already routed as I found better paths to link stuff up. Hopefully it will free up some area to route the more problematical signals.
Still routing away.. Found a "short" between the DMA and the shifter blue lines
That came about as I used "B0" in the DMA buffers chips, and "B0" for BLUE 0 on the shifter
Probably would have been a good fault though.. in that the floppy drive only works when blue isn't being displayed on the screen or something
Routing getting hard now. having to rip up loads of tracks and juggle to just route 1 now. Its got to the point of more like 1 or 2 track routes per hour now
Made a lot of progress though.. about 50% more done than last week.
As a side note, The low profile RTC boards are not forgotten about, neither are the TOS206 boards (which will be a replacement for the T-boards)
RTC
https://www.exxosforum.co.uk/forum/viewt ... 400#p24736
206 ROM board.
https://www.exxosforum.co.uk/forum/view ... 200#p22489
CHEAPO VGA ADAPTER
I'm going to try and finish some of these projects over x-mas.
RTC
206 ROM board.
CHEAPO VGA ADAPTER
Famous last words. I am sure another project will pop up to distract you.exxos wrote: Sun Oct 06, 2019 12:11 pm I'm going to try and finish some of these projects over x-mas.
Yeah 99% sure that will be the case.Icky wrote: Sun Oct 06, 2019 10:31 pm Famous last words. I am sure another project will pop up to distract you.![]()
Think the routing tool is on LSD again...
Busy routing for 11 hours straight
There was some DRC issues which should be fixed now.. at least on the part shown. I still need to sort out the GLUE to CPU wires yet..
I'm going to try and start doing some PSU builds tomorrow.. famous last words...
Yeah too right - you will still be battling the routing bugs and lose another 11 hours of tomorrow.exxos wrote: Mon Oct 07, 2019 10:45 pm I'm going to try and start doing some PSU builds tomorrow.. famous last words...
