exxos's DFB1 trials
Re: exxos's DFB1 trials
@Badwolf Suggested a jumper for the flash for bank switching. So just added that in.
@Badwolf stop distracting @exxos or it will never get sent off!exxos wrote: Tue May 02, 2023 8:26 pm @Badwolf Suggested a jumper for the flash for bank switching. So just added that in.
Sorry about that
@exxos: it occurs to me that with a fixed SDRAM memory choice, you don't need the ALTRAM jumper -- you could repurpose that as the bank toggle, or relabel it OPTION2 for some futher choice down the line.
Possibly.. or a altram disable jumper may be usefulBadwolf wrote: Wed May 03, 2023 9:39 am @exxos: it occurs to me that with a fixed SDRAM memory choice, you don't need the ALTRAM jumper -- you could repurpose that as the bank toggle, or relabel it OPTION2 for some futher choice down the line.
Though if my revision untimely goes in your GitHub then people may change stuff anyway.
Finished the BOM . Had a bit of a fight with it all. The good thing is there is a script to export in JLC format. In eagle I had to write my own scripts to generate the BOM in the correct format. So good someone did a kicad script to do it.
exxos wrote: Wed May 03, 2023 2:35 pm Finished the BOM . Had a bit of a fight with it all. The good thing is there is a script to export in JLC format. In eagle I had to write my own scripts to generate the BOM in the correct format. So good someone did a kicad script to do it.
I think I may have made a proper BOM once for a board with only passives on it, but I never got very far with anything complicated!
Things are officially done in the Pacman logo stamped on it
It has been sent off to the PCB company for a quotation. Probably be a couple of days or so before I hear back.
New boards arrived.. and with typical stuff goes randomly wrong, impact can't find my programmer now
Impact has *never* worked for me. I use xc3sprog.
That always worked for me in till today. Though I was screwing around with all sorts of USB drivers when trying to get the pico drive to work properly. So something could have broke then
