dml wrote: Mon Jun 23, 2025 11:41 am
I find in most cases, as the numbers become letters and appear more towards the end of the ID, the less important they are
Except when that isn't true of course. :p
Yeah, would be nice to actually confirm im not going to get a IC which is 5 mm smaller in size than the one I have all something like that!
Are you sure the short isn't something to do with the board though? Did you follow the short, cutting the track right up to the IC? Does it go anywhere else under the IC, maybe to the back of the board again? Just in case...
It's not just that one pin though it is basically all the databus from the flash...
Looking at the schematic it doesn't really go anywhere else and I even buzz around the board to make sure. Mostly just a pullup resistor pack and the ISA bus (nothing is plugged into the slots) so there simply isn't anything else on that track.
- IMG_3425.JPG (235.65 KiB) Viewed 353 times
The vias mostly seems to go downwards towards the flash. So I don't think it can be a PCB fault as it would have to have various faults on 8 data lines.
That flash databus only seems to go to the 2 big chips. Its obviously not the other big chip as the fault vanished. Doesn't seem to be any other tracks under the big chip but hard to tell.But I don't see anything else in the schematic anyway..
