I'm a hopless addict - PC Engine Duo inbound...
Re: I'm a hopless addict - PC Engine Duo inbound...
These consoles are known to suffer from SMT caps. Are you going inside while it is working? There is a nice, easy RGB mod to do at the same time.
https://8bitplus.co.uk/your-consoles/ne ... -upgrades/
Ah, the old 'let's make it cheaper, with less stuff, give it a cooler name and charge the same for it' plan.alexh wrote: 06 Jun 2023 11:42It's a cost-down. They removed the headphone jack and drive lock switch.rubber_jonnie wrote: 06 Jun 2023 10:43 Ahh, yours is the R model, what's the difference, other than the obvious casing differences?
Not that the drive lock switch is particularly spectacular, it's just a mechanical lock for the CD open button. I think the headphone socket is useful though.
Yeah, I already replaced a bunch of SMD caps in the video circuit, and will probably do the rest at some point in the near future, as I don't trust them.alexh wrote: 06 Jun 2023 11:51 These consoles are known to suffer from SMT caps. Are you going inside while it is working? There is a nice, easy RGB mod to do at the same time.
I may do the RGB mod, but for the short term the composite out is actually not bad, though my opinion may change once I try a game on it. That CD-ROM fix is interesting too.
In fact that site has some interesting info on it, will have a proper look later.
My Japanese parcel has arrived :)
Ooooooo........!
And here it all is, R-TYPE, a controller and a CD to test with :)
R-TYPE works lovely :)
And I think the CD problem is that the hub has dropped, as the CD is touching the case as it spins, so thanks to @alexh for the pointer to that :)
And lifting the CD drive hub about .5mm now has the cd spinning properly and not catching on the case - and it works!!!
These from a Super CD called PATLABOR - Chapter of Griffin:
I'm very pleased with todays arrivals and efforts :)
Ahh, R-TYPE is such a classic!!
I have to say, the image quality via my Dragon 32 composite/audio cable fed through my Retrotink to HDMI is really rather better than I could have hoped for.
Higgy
That is a cracking Composite picture.
I only have 1 CRT (out of quite a few :? ) that accepts a 60Hz composite signal and displays in colour. I suppose that is one of the main reasons for me RGB modding.
Your picture looks so good it goes not look worth fiddling about with.
I don't think I'll do the RGB mod, as you say it's a cracking picture, and the Dragon 32 cable also works fine for the sound as well.Higgy wrote: 06 Jun 2023 15:51 That is a cracking Composite picture.
I have to say, I struck lucky with that TV. It was a temporary fix for a dead TV in our bedroom years ago, but it will do 60Hz no problem and has a load of inputs. I got a similar one for £10 off ebay and that is good too, similar number of inputs, though a different aspect ratio. Both also have built in DVD players too :)
Users browsing this forum: Amazon [bot], ClaudeBot, gpt [bot], jmorden, OAI-Search [Bot], pazuzu72 and 18 guests
