It's 600XL time!
Re: It's 600XL time!
BennehBoy wrote: Wed Feb 02, 2022 4:16 pm Which IC type failed the tests? I've a bunch of 74 logic at home and 2 different ways to test them so I could see if it's a generic issue with the profiles that the TL866 includes - are you using the latest xgpro release?
Yeah, the version I have is the latest, downloaded in the last week or two. Unless of course there is a newer version!
The IC that failed was a 74LS51, all of the rest of the LS ICs passed in the TL866. The new LS51s failed identically.
I suppose as it's only a 2 output device, and the datasheet has the truth table, I could easily hook one up on a breadboard and see what the results are.
BennehBoy
Post by BennehBoy »
I don't have any 51's anyway :lol:
What does the delay line do? Is it just a series of inverters?
stephen_usher wrote: Wed Feb 02, 2022 4:41 pm What does the delay line do? Is it just a series of inverters?
Pretty much yes, but is vitally important to the way CAS/RAS works on these machines. The XEs used the Freddie chip instead.
There is a GitHub project: https://github.com/redhawk668/Atari-CO6 ... eplacement and a replacement has been made, which I am getting.
It uses resistors and a 74LS14, so in theory I could build one, just don't have the time right now as heading up to the Wirral tomorrow.
That's a very strange schematic. There's no input.
BennehBoy wrote: Wed Feb 02, 2022 4:33 pm I don't have any 51's anyway :lol:
Never mind, worth a try :)
stephen_usher wrote: Wed Feb 02, 2022 4:58 pm That's a very strange schematic. There's no input.
Yeah, it is weird. Also weird that on the original delay line IC, Atari cut a bunch of pins off that they didn't need, so theres only about half the legs on it.
Well, my replacement delay line just arrived, let's see if that helps
:crossed fingers: ;-)
stephen_usher wrote: Fri Feb 11, 2022 12:53 pm :crossed fingers: ;-)
Sadly not :( Bit of a head scratcher as to what's next, so I think back to the schematics, service manual and Google for more research.
Whilst I'm doing some figuring out, I will replace all of the boards single wipe sockets, I don't trust them to make contact properly as most feel a bit loose, and have the spares to hand anyway.
I have already changed the one for Sally and also the delay line, and since I have my desolder gun, it won't take very long at all.
Hopefully by the time I've done that I will have a plan, unless of course it fixes it!
