CeRiAl's H5 C1 Build
CeRiAl
Re: CeRiAl's H5 C1 Build
Post by CeRiAl »
exxos wrote: Fri Sep 17, 2021 10:12 pm Pretty much everyone on here has never run their machine with the shielding in place. I certainly haven't. In fact the whole remake project was developed that way. Using the shielding cannot do any harm at least, but it should not otherwise have any great effect on anything.
Guessed so beforehand, just wanted to rule this problem out! :D
exxos wrote: Fri Sep 17, 2021 10:12 pm If there was a bad connection on the audio circuit somewhere, could be very susceptible to RF noise. But otherwise it should be virtually silent noise wise.
I didn't know that a bad connection can make a circuit more susceptible to RF noise, learned something now, thank you! :)
Will check all connections audio-wise and on the YM, I hope I will find the culprit :D
| Atari 1040STF (4MB) | Phoenix H5C1 (in progress) | Amiga 1200 (ACA1221, Orinoco WiFi w/WPA) | Ultimate-64 Elite (Pixelwizard SX-64-Style) | Powerbook G4 (MorphOS-PPC) | TheC64 Mini (w/working keyboard) | Atari 800XL | Atari Portfolio | Newton MessagePad 2100 | ... and more |
CeRiAl wrote: Sat Sep 18, 2021 12:26 am I didn't know that a bad connection can make a circuit more susceptible to RF noise, learned something now, thank you! :)
Yep. CMOS type inputs you can turn things on and off by moving your hand towards such input. The whole motherboard is a RF noise generator. It doesn't take much for all that noise to couple to a floating input, but as to if that is your problem or not I don't know. Maybe there is a bad connection somewhere giving you lower audio volume than normal.
I would just do "finger on board" tests. Press down on everything and see if the noise changes. It may give a clue.
Return to “H5 C1 USER BUILDS”
