DFB1r4 design discussion thread
frank.lukas
Re: DFB1r4 design discussion thread
Post by frank.lukas »
Badwolf wrote: Sun Sep 12, 2021 2:08 pm ... so I might get some fine sandpaper on the terminals.
... that only makes it worse.
frank.lukas wrote: Sun Sep 12, 2021 6:03 pm
Oops. Too late!
Anyway reflowed, sanded lightly (*cough*), buzzed out my board. Still not working.
I suppose it could be a bad 2x25 female header, or a voltage that looks low on the probe but is ambiguous to COMBEL.
Anyone know a good place to probe A16-23 on the motherboard?
Badwolf wrote: Sun Sep 12, 2021 7:53 pm Anyone know a good place to probe A16-23 on the motherboard?
I would just ordinarily cheat.. Just have one probe on the known address lines on your booster board, and just run the other probe around the the board CPU on continuity test.
Trying to apply more brain to this, I can't think of single stuck (high) line that would cause a bus error on a longword read.
0x000001: reads ok
0x000002: reads ok
0x000004: reads ok
0x000008: reads ok
0x000010: reads ok
0x000020: reads ok
0x000040: reads ok
0x000080: reads ok
0x000100: reads ok
0x000200: reads ok
0x000400: reads ok
0x000800: reads ok
0x001000: reads ok
0x002000: reads ok
0x004000: reads ok
0x008000: reads ok
0x010000: reads ok
0x020000: reads ok
0x040000: reads ok
0x080000: reads ok
0x100000: reads ok
0x200000: reads ok
0x400000: reads ok
0x800000: reads ok
So it seems much more likely to me that a substantial proportion of lines must be reading as high.
It doesn't seem to be the motherboard as the DFB1r3b2 still works so what on the board could cause multiple (likely higher order) lines to read as 1 instead of 0, even though they seem to probe well enough?
Theories so far:
* Lines aren't driving low enough. Will have to crack out the scope to test this one.
* Something wrong with the data strobes? AS we know is getting through. We're not sure about the address lines, but AFAIK the only other players in the exchange with the mother board is UDS and LDS. Does anyone know what happens if no data strobes are issued, for example? These again read logically OK, but I think I'll need the scope on them.
* Timing? Perhaps AS or DS are missing some Combel timing gate? Clutching at straws now.
The (noisy) scope is probably not an option for a Sunday night in the living room so one other option is I pop the chip and write some firmware that just tries to read 0x000000 every few hundred cycles and see how that gets on.
I hate computers! :lol:
exxos wrote: Sun Sep 12, 2021 9:32 pm
My board covers the onboard CPU, irksomely.
Bah! It also covers P13, the pull-up pack for the top order lines. Grr.
OK, turns out the SDMA chip has all the address lines pointing straight forward so is easily accessible without the floppy in place.
A1 to A23 all buzz out with no evidence of shorts.
UDS and LDS buzz out to the GAL at U62
=> The connector is fine and so is the contact to mobo.
Focus shifts now on logic levels and timing & maybe I need to triple check the bus arb so the UDS/LDS translation GALs come into play.
Documenting the troubleshooting, reflowing the expansion and changing a fan whilst I'm at it.
Plus bonus recollections of the travesties I wreaked upon the poor beast back at university...
Frustrating!
Custom firmware that just does bus arbitration and then sets A and drives AS & UDS low every now and again -- no change, bus error.
Perhaps something fundamentally wrong with my firmware?
OK, let's port the old DFB1r3b2 firmware. Known good. Popping that board in works a treat.
*an hour and a bit later*
Screenshot 2021-09-13 at 23.21.04.png (58.67 KiB) Viewed 2703 times
Gaaaaah!
It *has* to be hardware on my new £50 set of boards. But what? What could cause this bloody odd behaviour? I need a flash of inspiration, I think.
I assume your falcon still boots as stock ?
No idea if you need LDS as well as should be 16bit access to ROM ?
exxos wrote: Mon Sep 13, 2021 11:47 pm I assume your falcon still boots as stock ?
Yes, boots with the DISABLE jumper set, boots with no board at all, boots with one of the older boards in place.
(LDS is also set, by the way, I'm only probing the one)
I think frustration got the better of me last night. What else could be going on?
For example, does anyone know how the COMBEL works? Will it assert BERR after 100 AS cycles even if it's already asserted XDTACK? Would this be the expected behaviour if XDTACK were being inadvertently driven high throughout?
I should check to see if XROM2 is ever asserted. Although that's a hell of a thing to probe!
If all else fails, I've another (lesser -- only a 144) CPLD and if I can canibalise an old board for a voltage regulator, I could build a partial second board to drive the lines in firmware again.
What larks. :roll:
