Falcon CA401332-003 Rev D/C Service blog
derkom
Re: Falcon CA401332-003 Rev D/C Service blog
Post by derkom »
Aha! Guess that got mangled when the old port was removed for whatever reason. Very nice work overall!
dhedberg
Post by dhedberg »
Great work fixing the Falcon!
Looks like that track could very well become broken again by the wear from the connector. The repair is in a bit of a bad position (it'll be partly or completely covered by the connector). Perhaps adding a bodge wire would be a better solution?
Daniel, New Beat - http://newbeat.atari.org.
Like demos? Have a look at our new Falcon030 demo It's that time of the year again, or click here to feel the JOY.
dhedberg wrote: Thu May 27, 2021 9:17 am Great work fixing the Falcon!
Looks like that track could very well become broken again by the wear from the connector. The repair is in a bit of a bad position (it'll be partly or completely covered by the connector. Perhaps adding a bodge wire would be a better solution?
Hmm I was going to coat it with PCB overcoat epoxy, but perhaps you're right. I'll add a bodge wire on the underside of the board just in case :)
Oh and we're not finished yet with this Falcon. That was just the first 'issue'. Second is that it is reported to be unstable with its ct60 accelerator. So I will be testing that and attempting to solve it.
Just checking with others familiar with the Falcon, isn't R221 usually 33ohm? This board just has a zero ohm... Odd.
mikro
Post by mikro »
R221 has been changed to 0 Ω in PCB rev.H.
Thanks @mikro :)
@mikro
With this particular revision:
Y43502003362
Are you aware of any factory fixes it may be missing, or is it a final revision? Thank you
mikro
Post by mikro »
It's hard to say, generally speaking, all boils down to having a good clock patch and maybe update the audio circuirty but I have personally never done that. So as long the bus is fine and there are no DMA issues, you're good to go. :)
UPDATE:
So, we fixed the monitor port - second job was to fix stability with ct60. This board had the 47ohm resistor termination 'clock patch' if you can call it that. Initially I removed this and replaced it with Exxos's clock patch, but upon doing this the system display would go crazy and garbled. LUCKILY Exxos was working on a similar Falcon and fixed the issue by using a 100k resistor on the sdma line. Thankfully this fix also worked on this Falcon! What a happy coincidence! :)
Photos of work in the last few days:
NVRAM replacement:
Clock patch install & 100k install:
ct60 ram shielding & replaced 220uf caps on ct60
Cleaning
Customer has some nice old stickers he always kept on the machine, as they are sentimental for him I carefully removed, cleaned & put back:
Working, testing some games!
Conclusion of story:
GATES HAS NO CHANCE!
Very nice work @Steve Good to know the 100K Also fixed the problem with your machine and also good to know the exxos clock patch works with the CT60 :) :thumbup: :cheers:
