TF536 Firmare Update RC3
alexandregatt
Re: TF536 Firmare Update RC3
Hello, after this update, I have no more bugs. Thanks for this work. Everything is perfect...
Has anyone (other than GadgetUK) got SCSI cards to work with TF536 after the RC3 firmware update?
Works fine for me here with an A2091matt020 wrote: Wed Apr 21, 2021 2:22 am Has anyone (other than GadgetUK) got SCSI cards to work with TF536 after the RC3 firmware update?
- Gleylancer
Is this the only way of updating the TF536? I'm baffled by the sheer amount of hardware and effort that's needed to do this. O.oobitus1990 wrote: Fri Apr 02, 2021 3:28 amI found this to be very helpful:Seb132 wrote: Fri Apr 02, 2021 2:46 am Is there a post for Newbies with a "how-to" tutorial explaining how to flash a TF on general and a TF536 in particular ?
I'm in Australia and never done this before...
Also is there a sticky post for all the latest firmwares of all TF cards ?
I have a TF330 also and I'm not sure what is the latest firmware for it and if I have it...
Thank you.
https://linuxjedi.co.uk/2020/12/01/prog ... pberry-pi/
- Admin sponsor
Baffled why? Thats the cheapest way to do it. You can buy an expensive XIlinx programmer as an alternative.Gleylancer wrote: Fri Jun 11, 2021 8:27 pm Is this the only way of updating the TF536? I'm baffled by the sheer amount of hardware and effort that's needed to do this. O.o
It's really not that expensive, $30 on ebay.terriblefire wrote: Fri Jun 11, 2021 8:33 pmBaffled why? Thats the cheapest way to do it. You can buy an expensive XIlinx programmer as an alternative.Gleylancer wrote: Fri Jun 11, 2021 8:27 pm Is this the only way of updating the TF536? I'm baffled by the sheer amount of hardware and effort that's needed to do this. O.o
- Gleylancer
As a naive and highly inexperienced amiga newbie, I was probably expecting to just do it from one of the internal storage options, but I suppose that's not possible.
- Gleylancer
That looks like a much easier way, I'll just get one of those. Thank you.It's really not that expensive, $30 on ebay.
Please be aware that you will most likely need a 32 bit windows to run the Xilinx ISE (14.1) and the programmer drivers. Even if you have an old WinXP machine it will be fine.Gleylancer wrote: Fri Jun 11, 2021 8:52 pm
There's a workaround to get it to work on 64bit win10, couple of files to replace. Details on here -> https://alchitry.com/pages/installing-isealenppc wrote: Fri Jun 11, 2021 9:06 pmPlease be aware that you will most likely need a 32 bit windows to run the Xilinx ISE (14.1) and the programmer drivers. Even if you have an old WinXP machine it will be fine.Gleylancer wrote: Fri Jun 11, 2021 8:52 pm
