Re: REV 3 - The beginning
@frank.lukas TOS206 an TF536 works fine on its own.. it malfunctions when using MAPROM...
Got distracted with the ROM decoding https://www.exxosforum.co.uk/forum/view ... =20#p60413
But follow the red wire and the TF536 is now providing the ROM decoding output for the H4..
I guess I really need to solder a ROM socket on the TF536 to make sure it works as intended next
@PhilC can try it
I just love the way you're supporting your scope
I know!! is only free real estate I have left
I am really wondering how long it will take for the toroidal transformer to wipe the floppy as well
So with some kind help from @Badwolf With the Verilog code.... I am now running this at 50Mhz! scores overall are fractionally slower than my 68000 50MHz booster, but that is likely as I cannot coax anymore speed out of the ROM like I could the ST.
TF536 50MHz..
68000 50Mhz.
Next to get TT RAM working...
TF536 50MHz..
68000 50Mhz.
Looking very promising
Looks like your integer division is still a bit low, which probably accounts for half the speed difference. Should be 1.82 seconds for a 50MHz 030 with caches on.exxos wrote: Mon Mar 29, 2021 10:04 am So with some kind help from @Badwolf With the Verilog code.... I am now running this at 50Mhz! scores overall are fractionally slower than my 68000 50MHz booster, but that is likely as I cannot coax anymore speed out of the ROM like I could the ST.
Chip another couple of DTACK delays off!
I am not sure if it is or not, because speeds are double when GB6 is running from TTRAM... As the tests are running from ST-RAM it as the code overhead which is probably why slowdown is there...Badwolf wrote: Mon Mar 29, 2021 10:55 am Looks like your integer division is still a bit low, which probably accounts for half the speed difference. Should be 1.82 seconds for a 50MHz 030 with caches on.
I don't really have any reference to what it is supposed to be..
TTRAM is being a bit sulky for some reason... FASTRAM.PRG just freezes after saying the RAM is installed, GB6 can install it but then I get screen corruption... The RAM is present as I poked some addresses in STOS..
It looks like that odd address range corruption issue is back
I wonder if there's a bad connection somewhere...
TTRAM isn't behaving for some reason ..
The integer division is consistent across ST-RAM and AltRAM.exxos wrote: Mon Mar 29, 2021 11:06 amI am not sure if it is or not, because speeds are double when GB6 is running from TTRAM... As the tests are running from ST-RAM it as the code overhead which is probably why slowdown is there...Badwolf wrote: Mon Mar 29, 2021 10:55 am Looks like your integer division is still a bit low, which probably accounts for half the speed difference. Should be 1.82 seconds for a 50MHz 030 with caches on.
You had 1.820 in this post with AltRAM, and here's my 50MHz 030 with ST-RAM only:
Bang on.
BW.
